Components from unpublished library show up in search results
Dario_Stefanutto
Hello, I’m having an issue with the Assets tab. When I search for a component, the results show components from libraries that are either deactivated or unpublished, with the result that it’s hard to tell what version of a component is the one I want.
I only have 1 library active and I’d like that only the components from that library would appear.
Any solution? Did you also encounter this problem?
Thanks!
  • 4707 replies
  • April 23, 2021
If you are using the unpublished components in the file, they would still show up in search. You can create an instance of this component and use Instance Finder plugin to find other instances of it in the file to check.
  • 4707 replies
  • November 10, 2021
2 posts were merged into an existing topic: Enable Assets search only for enabled libraries
