Allow Hover AND Click together
Show first post
James_Wagstaff
How in god’s name has this issue been open since 2021? It isn’t a feature request, it’s a bug report. This is really fundamental functionality.
Jaakko_Haaparanta
You can also use a boolean variable to toggle the visibility of a tooltip on mouse enter and leave. This works fine together with a click interaction as long as the tooltip is already absolutely positioned inside the component/variant.
JessB
  • August 5, 2024
So at the amount we can either for examples make a component either hover or click. Why can’t we have the ability to do both I aka hover so it shows hover. Then I click and it changes to click and move
Dennis_N
  • 193 replies
  • August 5, 2024
The component indeed can’t have both but the instance can have the click event in addition to the hover which is controlled by the component.
If you would like to have all within the main component you could maybe use the “mouse up” respectively “touch up” trigger as a workaround on your hover state.
Btw, there already is such a feature request you can vote on:
Geoff-Colbath
  • 9 replies
  • September 26, 2024
Maybe @Figma_Product should merge this with the other issue, then?
Geoff-Colbath
  • 9 replies
Spoke too soon… looks like they already did. Thanks, @Figma_Product!
Khoji_For_Agile
For instance, if I’ve added a hover effect to all the rows in my dropdown, I also want the click action to function properly. Currently, I have to remove the hover effect first and then apply the click action, which can be annoying especially when working with components.
Dan15
  • 41 replies
  • October 22, 2024
I think it’s because of how they’ve built this feature. Basically, the hover state replaces the default state, so I guess they’d need to be able to place a click event on the hover object from the default one… Still such a stupid problem.
Replying to keep this ancient effing thread alive… 💀
Mark_Quad
  • October 29, 2024
Absolutely ridiculous that a hover state change with a click action on a button component. is not possible to prototype in Figma. Not even getting into the ridiculously complicated and chaotic “state management” that Figma cooked up.
I regret moving from Axure to Figma so much that I am now considering to invest the time to switch back. True prototyping in Figma is simply impossible with the current architecture.
Luis_Lopez1
  • November 1, 2024
I agree Mark, simple things like this would take a couple of seconds in Axure … but present a world of hurt when trying to protype it in Figma … Its an amazing tool for layout and design systems keep everything nice and tidy … but the maturity level of its prototyping is just enough to go from one screen to another or present hover states. Developing good UX is overly taxing and I end up having to explain in exhaustive step by step detail what each interaction needs to do … Figma can do better … i know they can 🙂 … Take a break from the dev side … and get a team to help the prototyping side of things 🙂
Franni
  • 18 replies
  • November 22, 2024
I really can’t believe I still have to struggle with this after YEARS xD
Julie_Pronzac
S-O-S ! I’m desperate because I spend so much time on this…
Tony_Tansley
coming up on 4 years!!! come on Figma, this seems pretty basic???
Pavel_Kiselev
  • 438 replies
  • December 5, 2024
If you are looking for workaround that does not overlap with other layers, here is something I use for a long time → Tooltips inside trigger component, or separately? - #5 by Pavlo_Kiselov
D111
  • December 6, 2024
Please do it already! While you try to make tools for developers, you absolutely forget about designers!
tomato24
  • December 11, 2024
Figma please bffr I am absolutely losing my mind trying to figure out what feels like a table stakes prototyping feature.
Matthew_Schwartz
It’s absolutely insane that you can’t use a hover and click interaction on the same element.
This has been such a long standing issue that so many people want.
Why is it not being added?
Artem_Shatalov
Just to keep this thread up to date. Absolutely need this.
Thanks
Marlon_Delgado
It's crazy that as of today (2025) this interaction cannot be carried out.
wc-xym
  • 5 replies
  • February 18, 2025
I have tried splitting hover and click up into two different layers. Sometimes it works, and sometimes it doesn’t.
Dima_Siefier
  • February 18, 2025
Component Variants solution:
Lauren29
  • April 4, 2025
Kind of embarrassing to explain to my manager that I can’t mock a button with a click and hover state at the same time. Please fix.
Sasssdfasd
  • April 7, 2025
The problem with this solution is that you will have your tooltip under near elements if you have no free space around element you are interacting with.
For example tiles view.
But hey. At least we have Dev mode that nobody cares about and UI redesign nobody was asking for.
As if Adobe sent it’s agents to sabotage Figma from inside...
Kateryna_Tolstaia
Such a shame that long standing issues are being shunted aside in favor of features no one asked for.
Zoe_Gomez
  • Active Member
  • 26 replies
  • April 9, 2025
pleaaaaaaase
