h.rude
Apr 26, 2021 9:00 AM UTC
Allow Hover AND Click together
With the interactive components, a variant can now have a tooltip. But unfortunately hover and clickactions are still mutual exclusive.
I’m designing for a desktop application and having a tooltip per inputelement/button is crucial.
Laszlo_Ambrus
May 10, 2021 10:06 AM UTC
Yes, I agree! Maybe we’re too demanding. 🙂
We moved from Axure + Sketch + InVision + Abstract + Zeplin over to Axure + Figma and the workflow is much less painful!
We still use Axure for UX and to create the fully functioning prototype. Axure can do really complex stuff, like databases, that we can’t (yet) reproduce in Figma.
For complex animations without any code I still find AE to be the fastest, although I’m wanting to check Principle or Protopie, but never find the time to properly dive in.
Anyway, let’s hope our prayers get answered and waking up in the middle of the night from a component nightmare will be a thing of the past. 🙂
Kamil_Wanzek
Jul 21, 2021 4:41 PM UTC
Hi, I recantly also across on this problem and to be honest there’s no clear workaround to this. There’s no possible way to add hover and click interaction to the same frame and display in on preview with interactive components. But I use imperfect solution that may be also help with your problem.
I discover that it’s everything fine when variants don’t have layers that overflow basic size. Problems starts when you have tooltip that goes beyond box size.
I deal with it by for example adding hover interaction to the 24x24 icon (overlay set manually to present tooltip) and then nest this frame with another frame 40x40 (touch target) and on that parent frame add click interaction. (Details in video).
I think when interactive components leave beta, Figma team will solve this problem but for now we must carry on with imperfect tricks. Glad if this messeage help someone.
Roderic_Mul
Aug 6, 2021 8:58 AM UTC
I made a workaround and managed by applying the ‘on click’ event on the ‘open overlay’ element.
So the on click event is NOT applied on the initial button. But the element that is the actual rollover state.
h.rude
h.rudeAuthor
Aug 6, 2021 9:20 AM UTC
Just to make it clear - you open an overlay on click (e.g. toolitip) and then if you click on the tooltip you go to the next screen, right?
The only issue I still see here is, that it is not reflecting a real flow … a tooltip does not show up on click normally. And how should a tester know, that he needs to click on the tooltip instead of the button (except that the tooltip gets highlighted when clicking somewhere in the prototype window)
But still, a good work around if you as a designer just want to show the different states 🙂
Stefan_Ganchev
Aug 11, 2021 6:32 PM UTC
Here is my solution for a button that has on and off state and a tooltip.
From the main screen I created a hover open overlay interaction link from the button. The link goes to a frame with both the tooltip and the button as children, where the button has opacity of 0%. The button then has a click interaction which uses swap overlay going to another frame of the same dimensions but without the tooltip and the button with on state. The button’s interaction here is close overlay on click.
Andy5
Aug 13, 2021 8:30 PM UTC
I think my request is in the same vein here, but I’ll add my use case just for context.
My use case: I want an edit button to appear over a section of the page when you hover on that section. What I’ve done is create a component that is just an empty frame with an edit button in the upper right-hand corner. The edit button itself is a separate component that has a hover effect wired up within its variant group. For each section, I want to set up separate click interactions that open different modals.
The problem is, it seems like I can’t set separate interactions for different states of a component. When I hover over my empty frame, the edit button appears, no problem. I then move my mouse over to the edit button which then triggers the hover effect for that button, great. The problem is these are both buried under hover interactions, so in the actual design mode I don’t see these objects by default. I can go to the component panel and turn on the hover state for each of them, then create the prototype interactions, but Figma doesn’t seem to remember these actions when in prototype playback mode.
I think this is the same thing OP is getting at — allowing a hover and a click interaction to exist on the same component instance.
GameClude
Aug 20, 2021 6:28 AM UTC
@h.rude Hello
I think I found a perfect workaround, I’m still testing all outcomes but so far so good
Create your tooltip / make it a component / make an instance of it / create your icon and do the same / put both instance and icon in a frame with the right way of hovering and auto-layout/ make it a component / make it a variant/ name variant 1, Visible=True / name variant 2, Visible=False / now in variant 2, reduce the visibility of you tooltip to zero=0 / make a prototype of false to true by mouse enter and leave / now put you false variant into your design and link by click to wherever you want
this way when you hover one there is a tooltip and without overlays, so you can click through it and it’s easier than it sounds, when you put in the design there is no need for hard work anymore and you have a nice component with tooltips
PS: I haven’t still test it inside a full page and messy auto layouts but I think it should work fine if you make a good auto layout
Simit_Rajwadi
Sep 3, 2021 2:35 AM UTC
@h.rude
I have tested what @GameClude is describing. It takes a little extra time to set up but does work.
Here’s a tutorial that helped create the components
Rory_Smyth
Sep 6, 2021 8:57 AM UTC
Also ran into this limiting issue pretty quickly using interactive components. The use case is around needing things like tooltips and hover states on a button along with a click. The workaround of embedding the tooltip into the components themselves isn’t one that fits in with a flexible design system.
I would consider this a basic interaction.
Jack_Taylor
Sep 10, 2021 9:27 AM UTC
I can’t believe this isn’t possible - especially since it lets you create this interaction with no kind of suggestion that it won’t work, but then it just doesn’t work on the Prototype 🤔
