Variables + Components with variants doesn't work
Robert_Powers1
Steps to replicate.
  1. Make a string variable tt with the value of “Target Text”
  2. Add a text input to your stage and bind the tt variable to the text field.
  3. Create a component with two radio options A & B
  4. Make variants for each with selected states and create OnTap Changeto action + actions to set the variable field to A or B.
  5. Drag in a variant of the radio components.
  6. Test prototype
Expected results
  1. The text variable changes to A or B
  2. The selected state changes between variants
Actual Results
  1. The state changes but the string variable does not update.
Best answer by Robert_Powers1
OK. I started a new file and for some reason is was something buggy in the file.
It’s working in the new one…Thanks.
One thing to also note is that I think the bug was occurring because the radios were made from component sets that were made from components and it was causing some confusion in Figma. You have to break all connections to the component.
  • June 27, 2023
I’ve got the same issue. Would love a fix for this asap!
  • 4873 replies
  • June 27, 2023
Robert_Powers1
That still doesn’t work.
  • 4873 replies
  • June 27, 2023
I just recreated your example, reordered the actions so that “Change to” is the last one in the list of actions, and everything works as expected.
Robert_Powers1
Please publish and share your file.
I’d love to see how you have it assembled.
  • 4873 replies
  • June 27, 2023
Everything can be seen in this screenshot:
Robert_Powers1
Weird. I rebuilt my completely and it still has issues. Only the first action triggers.
Also how do you get the little variable links to display in the canvas? They don’t display in mine.
This
  • 4873 replies
  • June 27, 2023
Are you sure you reordered the actions? Take a close look at the interaction modal windows in my screenshot. As soon as the first action in the action list is “Set variable”, you will see the corresponding icon on the canvas when the Prototype panel is open.
Robert_Powers1
  • July 27, 2023
