Jul 11, 2024 2:39 PM UTC
I can’t find the “properties panel”
The panel “properties” on the right side is not available, I cannot make it to appear, It doesn’t matter if there is a selected object or not. This happens in any project, new or existing or even in a copied project from other teams. I can’t find the option of activating the properties from my two accounts below (notobd4x4@gmail.com and obandemanny17@gmail.com) kindly look into this please.
Nellya
NellyaSolution
Power Member
Oct 1, 2024 6:38 PM UTC
That’s not a bug. There is no Properties panel for owners of the file anymore. It is displayed only in view only mode. So, you need to be viewer, not a owner or editor to be able to see it.
Figma Learn - Help Center
Jul 12, 2024 12:12 PM UTC
Same problem
Jul 12, 2024 7:11 PM UTC
Is there a fix to this ?
Jul 25, 2024 9:13 PM UTC
Hey @obande_emmanuel, thanks for reaching out and so sorry for the delayed reply!
It looks like you’ve reached out to the support team on ticket #1063294, and Isabella replied to you last week. Please continue working with support directly. Check your inbox and possibly your spam folder, if you haven’t seen the response yet.
Edward_Mosley
Sep 30, 2024 4:14 PM UTC
So is there actually a solution? Or no?
Oct 1, 2024 6:13 PM UTC
Hey @Edward_Mosley,
It looks like support never received a reply from Obande, but here’s what they asked for to start troubleshooting the issue:
Please provide a video recording of the issue, including the whole window with the layers and missing properties panel in view and relevant layers expanded. Be sure to select any layers you’re having trouble with, so we can check any relevant settings.
We can use the video to try and reproduce the issue in our own file. Showing all the steps needed to reproduce the behavior is helpful.
Nellya
NellyaSolution
Power Member
Rijashah
Feb 26, 2025 5:44 PM UTC
I'm facing the same issue
demi ogorman
Mar 17, 2025 12:03 PM UTC
I am also facing the same issue - is there a solution to this yet?
Sajid Munawar
Jun 19, 2025 7:38 PM UTC
thank you so much for your clear answer.
