(Solved) Boolean property / Hiding frames in component
Simon_Friis_Hansen
Very excited about the improvements to Figma!
I’ve dug into the new possibles for components and got the impression that the Boolean property can be used for hiding/showing elements instead of using variants. This would reduce the amount of variants needed for my button component and as such be a welcomed change!
However, I don’t see the Add boolean property option on frames in my component. So far I’ve only found the option on images - is that by design, @Figma_Support?
Edit: Never mind, found the answer in Cannot apply “boolean property” to sub-component: the Boolean option is always in the Layer section, which is placed differently depending on the element type. Couldn’t find it where I looked for it, but it was further down.
Simon_Friis_Hansen
I was able to shave a component from 36 variants to 2 as nearly all variants served the purpose of hiding/showing something. Love this improvement!
Bruno_Barros
@Simon_Friis_Hansen have you been using base nested components in the 36 variants you mentioned? Have you run into this issue?
I’d love to reduce the number of variants I have, but it seems component properties weren’t design to work as part of base nested components (since changes made in those properties aren’t reflected in the variants).
Alexandre_Istrasoft
all of the new fancy stuff should work with nested components, otherwise most of it will be useless to a large part of the designers…
  • June 10, 2022
