It would be great if the professional plan offered more than 4 variable modes. Right now I want to set up a mode for each component size-- XS - XL, 5 sizes all together-- which puts me over the 4 limit for pro, but well under the 40 limit for enterprise, which is a quantity I will never need. And there’s no use case for enterprise at all for a team our size. I think 10-12 modes for pro would be perfect to give small teams like mine room to grow before we reach the scale where an enterprise plan would be worth consideration.
Hi! I’m Avery a student, and I was wondering why my verification is requiring me to login with my school email? I would like to keep this account since it has all of my projects. I am also authenticated via google oauth on this account. Why do I need to change my email to verify? Thanks, Avery
limit until 7 jun 2025, but it is 7 jun 2025 and still unwork
I was trying to clean up a file and move some older stuff to an “archive” file. I accidentally used cmd + x and cut the frames I wanted to move. Now when I try to paste them, Figma hangs for a minute, then the frames all show up as if the paste worked, Figma is unresponsive for a moment — then I get an “Open this file in recovery mode” modal, and when I do so all the pasted content disappears. You can see it in action here: https://monosnap.com/file/3VMxNwbMXEoFAkDcUNR2JH7t4jcmUQ I can’t seem to get around this. I’ve tried the desktop app and multiple browsers. I’ve tried using a new file, restarting Figma, and wiggling my nose in every direction during the paste… Any idea how I can get these frames out of my clipboard and back into Figma? Is there some way I can paste the data into another app and attempt to break it up into multiple pastes? It’s not even THAT much stuff, but I guess it’s just a teeny bit over the line for what Figma can handle. Any advice would be greatly appreciated
Hey ,Its glad to hear that we have figma dev mode server , well done folks . but there is a problem most of the time i am facing i given a figma frame link it fetched the frame correctly but it generated completly a wrong screen which was not even 1% equavalent to what i gave .i used claude 3.7 model for the generation . Figma generated this screen (output) Figma frame input
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure. Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component. What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
When presenting interactive components with a hover state, the cursor sometimes shows the pointer hand on hover and other times does not. Curious if I’m experiencing a bug or missing a setting. Thanks!
Is there a way to iterate something I created with figma make on figma design? I already arrived to a good result but I can not take the results I have to a user flow on a figma design page :(
@Junko3 This issue is still persistent today. Actually there’s 2 issues here, depending how the component is built: Firstly a nested component that uses slots loses any override when using variables, this is not the case when changing from UI For components that have nested components in the master pre-made, without using placeholders, it is not possible to use DIFFERENT variables if the variant property is the same. In my example the blue instance has a light and dark variant. The property name is “blueProp”. Because the blue instance appears twice in the green component, the “blueProp” also appears twice in the nested component panel. See attached video for these 2 problems. Master with pre-nested instances: No problem while using UI Same setup but I cannot use different variables for different nested instances Master with placeholders / slots: No problem while using UI Using variables breaks / loose overrides I can provide the file if needed. Test with Figma Beta freshly restarted a
Is it possible to map the HUG or FILL to a variable. It would be great to not only assign particular width values, but also set the width to either hug or fill the container.
Very low performance speed in Figma Make when the thread reaches large sizes (currently 230+ iterations). All actions in the chat area occur with a significant delay (typing, scrolling, etc.), making it impossible to work. However, the prototype itself works well within FM. Has anyone encountered this? What could be the cause? Could it be related to the power of the laptop?
Hi, I need urgent help recovering a project file that suddenly disappeared. Yesterday I worked on it from my main device — everything was normal, and I closed the file as usual.Today, when I opened the same tab again (on the same and another device), I saw a message saying the file was deleted. I checked all folders, Recents, Drafts, and Trash — the file is gone.I also followed the official instructions from the Help Center (including checking the Trash and applying the "Created by: Anyone" filter), but still couldn't find the file anywhere.There were no sync issues while working, and I had full editing access — possibly even ownership. This project is very important and I need to recover it as soon as possible.I'm currently on a Starter plan and can’t reach email support directly, so I really hope someone from the team or community can help, or escalate this internally. Thanks in advance!
Right now in Buzz if you give someone a template and want to let them swap out an image, they can only Upload an image from their computer to “replace” the image, OR drag in an image from a library from scratch, but it won’t replace the existing image. Uploading an image from your computer is a good way to replace, but we want to give content editors a library of images to choose from that we curate. Ideally in this view there would be a Library icon, and then we could choose a photo from a Library to replace the image. This feels like a big miss compared to Express, which handles this much better.
Find answers, learn more.
