I’m trying to create a button, using my variables for correct coloring on themes. My actionable icon hover is connected and showing up correctly However, when I place this component in the button lock up - the surface/default changes from light to dark - even though no variables modes are set on the component/frame/or section. No variable modes applied (on component/frame/or section) And I know this is true since my actionable icons component lives within the same frame & section and is appearing as wanted How do I fix this? Please help
Yes I know this topic has been raised before, but I would like to raise it again, since it is breaking the core interaction in my design system. Is Figma even aware of this issue? Since the last discussion about it is ~2years ago, and this issue still exists. Steps: Create a Button component set with 2 variants: Default, On Press Add interactions in the variant: “Default” → While pressing → Change to “On Press” Insert an instance of the “Default” button into a new Frame Add interactions to the button: On Click → Open overlay. Check the “Close when clicking outside” box. Test the prototype Results When you click the button, the button change to “On Press”, the overlay opens, but when clicking outside the overlay to close it, the button does not reset back to “Default”. Expected: The button should reset to “Default”.
Всех приветствую! Открываем топик для общения на русском языке. Пишите свои вопросы, пожелания, идеи. Официальное сообщество в России Figma Moscow Телеграм канал с анонсом всех новостей Мероприятия, которые будут по Figma, параллельно официальному сообществу буду анонсировать тут: Мероприятия по теме Figma (RU)
Hello. I was wondering if it is possible to have percentage values in variables, like setting percentage value for frame widths or shape sizes (etc.) that have variable modes applied to them? Percentage values could respond better to content that varies within a frame or frames within frames.
Firstly great job Figma Font variables are here!!! Figma tutorial: Variables for typography The only thing missing is the use of percentages in the line-height property. You can not use a percentage in the line-height as it only accepts variables that are a number type. Although the variables for line-height caters for pixel (absolute) line-heights (10,12,14)- it does not accommodate relative line heights. In other words you can’t use percentage variables for line heights that are a percentage of the font size (100%, 120%,150%). Interestingly …You can use a variable for letter-spacing ( which accepts a number variable - but reads it as a percentage) - the challenge remains that line heights by default are absolute not percentages - even though you can input a percentage. Percentages allow greater flexibility and less calculations Word around would be to allow formula in a variable e.g. =[variable] * 1.5 Or figuring out a way for the line height to be toggle between absolute or relative
In Figma Make, how do you delete extra or empty files from the code tree? I can’t delete them or prompt the AI to delete them successfully. I’d like to make sure they do not confuse future prompts.
Since the last update, it’s impossible to copy and paste the image fill, into another component. I’m working with Auto Layout and I used to be able to select the fill > copy this > open another component > select the fill > paste. This doesn’t work anymore. It’s a feature I use all the time. Does anybody else experience this?
I was going to praise how neat the new Annotation feature is, when I realized the content is only visible to Dev Mode accounts. Are you serious? I understand you want to limit creating annotations to certain seat types, but viewing annotations should be a viewer-level feature. Come on Figma, there are better ways to convince your users to pay for a subscription. This is such a crooked move.
Hi Figma Team! I’d love to request a small but meaningful feature: Could you please make Figma remember the UI state (e.g. when panels are minimized) across sessions? Right now, even after clicking “Minimize UI”, the left and right panels open again after restarting the app. For those of us who work in a clean, focused canvas — having to manually hide the UI each time is a bit of a chore. Would be amazing to have an option like “Remember UI layout on startup” or “Start with minimized UI” in Preferences. Thanks for all your hard work — Figma is awesome! 🙌
Hello 👋, Our team is very enthusiastic about the Figma Buzz concept, we decided to try it out. I created templates, locked the layers that don't need editing, published them, shared them with my colleague and gave him editing permission. My colleague logged in but was able to edit every layer of the template, also the locked ones. And also if he uses that template in a new file. Could you help me find out what's wrong? Why Figma Buzz doesn't meet our expectations? In the first screenshot below, we see the layers are locked in design mode. And in image 2 and 3, we see the user the template is shared with able to edit the same layers, while in Buzz mode. I cannot find similar questions in the Forum. Are we the only team having this problem? 😔For now we've concluded that Figma Buzz's beta version is not sufficiently developed for our current collaboration needs. Because we did not experience the anticipated 'simplified editing experience.' Thanks a lot in advance!Marinske
I have searched and can’t find an answer. I am a bit surprised this isn’t already a feature. I would like to hide the selected object’s BLUE OUTLINE with a key command or in the View menu. Please and thank you.
I work with 2 co-workers, one (like me) focuses on UX Design, the other is in charge of the design system and token files. When doing some file clean up I discovered in the token Figma file, I had 200+ changes to Publish. The other UX designer showed that as well. The coworker in charge of the token files showed no changes to Publish, and nothing to update. We all then checked our version history and they are the same time and date. Any idea what could have caused this or how to fix it? We are using a company account, and I believe we all have the same editing credentials. Not sure what other variables would cause this misalignment in the same file.
Find answers, learn more.
