[Fixed] File won't open? Stuck loading?
Ignatius_Anggara
Hi. I was just going to go to Figma and open projects but my project won’t even open
It stays load for indefinite
Is there any suggestions?
Best answer by thudson
Our engineering team was able to roll out a fix and have verified that it has resolved the issue here.
We apologize for the inconvenience. If you’re still having issues, please reach out to our Support team via email or the widget in bottom-right corner of Figma – we’re happy to help!
Yael1
  • June 13, 2021
I can access my Figma home page (online using the app) but when I try to access a file it starts uploading and gets stuck at the end.
This happens with all my files.
Sent a message to support twice and they never replied.
Please help…
Long_Hoang
So is my problem.
Let’s fix it soon
Ganesh_Gholap
same for me 😟
  • 4708 replies
  • June 14, 2021
Everyone who is having this issue, you need to contact Figma support!
Send them the file link, console screenshots and other information you may find relevant.
Anak_IT
  • June 14, 2021
ya, same for me, i see i developer mode in browser, please help me!
Tushaara
  • June 14, 2021
I have been having this problem since 2 days ago, using the Figma desktop app. And I have checked that Figma is up to date, my MAC OS is updated. Restarted my MAC multiple times.
Please help to resolve this?
Allan2
  • June 14, 2021
Same issue here, please help 😭
o.verflowhidden
The situation is very urgent right now, has anyone solved it? 😢 😭
Justice_Jersak
Came back after taking the weekend off and having the same exact issue as everyone else here.
exc4libur
Same problem here! Mine got stuck at around 95% too. I’ve tried switching to different browsers, using the desktop app, etc but the problem is still there. Anyone got a solution?
Revaldi_Bagas
I got a problem with one of my project files. I can’t load the file, it took forever to load. I’ve tried load the file with different device and still face the same problem.
And somehow i can’t duplicate the file, it says like this
exc4libur
Hi! I have a Figma project that apparently cannot be opened now because it’s stuck on the loading screen for hours.
Here’s what I’ve tried so far:
  • Changing different browsers: same… the files still got stuck around 90 - 95%
  • Clearing browser cache: still stuck
  • Tring out using different computer/pc: still stuck
  • Switching to previous versions (Alt + Shift + click): prompts an error message that says “unable to switch to the previous version”
  • Tried duplicating the files: prompts an error message that says “unable to duplicate files”
  • I’ve attached a preview above for the browser console … I hope anyone can find a solution for this.
If any one of you encountered a similar problem and solved it, please let me know!
BOYSO
  • June 14, 2021
Same problem here!
asendia
  • June 14, 2021
Dao_Trung_Dung
I have the same problem. Pls Help us
nakajima
  • June 14, 2021
Please help us!!
Ganesh_Gholap
Now I don’t see that file on the Figma anymore. Is Figma working on it?
Gopi_Krishna
Facing the same issue. Some of my other files seem to work. But the most important one needed for the next dev sprint is stuck in loading screen 😦
thudson
  • Support Engineer
  • 16 replies
  • June 14, 2021
Hi and thank you all for your patience!
We’re investigating this issue now and will be updating our Status Page with more information as we learn more.
We appreciate your patience as we get this resolved!
Gopi_Krishna
Hi my file is loading now! thank you. First thing I did was save the .fig file locally 😃
exc4libur
Hi, the problem seems to be working now. I don’t know how, but the files seems to be working again. Thanks for the support!
thudson
  • Support Engineer
  • 16 replies
  • June 14, 2021
Anak_IT
  • June 14, 2021
Thank you sir
Yael1
  • June 14, 2021
My files are still not opening 😢
Alisa_Sukhanova
After updating Figma, I have troubles using it. It is loading for ages and I can’t open anything. I tried reinstalling the app, but it’ didn’t help.
Debug:
Figma 98.13.0
macOS 11.4.0 x64
Electron 12.0.9, Chromium 89.0.4389.128, Node.js 14.16.0
Sentry issues for user
Hardware
Model Name: MacBook Pro Model Identifier: MacBookPro16,1 Processor Name: 6-Core Intel Core i7 Processor Speed: 2,6 GHz Number of Processors: 1 Total Number of Cores: 6 L2 Cache (per Core): 256 KB L3 Cache: 12 MB Hyper-Threading Technology: Enabled Memory: 16 GB System Firmware Version: 1554.120.19.0.0 (iBridge: 18.16.14663.0.0,0)
Graphics
2d_canvas enabled
gpu_compositing enabled
metal disabled_off
multiple_raster_threads enabled_on
oop_rasterization enabled
opengl enabled_on
skia_renderer disabled_off_ok
video_decode enabled
webgl enabled
webgl2 enabled
  • NSScreen Встроенный дисплей Retina {{0, 0}, {1792, 1120}} Цветной Р–Рљ-дисплей colorspace (P3 capable) Intel UHD Graphics 630: Chipset Model: Intel UHD Graphics 630 Type: GPU Bus: Built-In VRAM (Dynamic, Max): 1536 MB Vendor: Intel Device ID: 0x3e9b Revision ID: 0x0000 Automatic Graphics Switching: Supported gMux Version: 5.0.0 Metal Family: Supported, Metal GPUFamily macOS 2 Displays: Color LCD: Display Type: Built-In Retina LCD Resolution: 3072 x 1920 Retina Framebuffer Depth: 24-Bit Color (ARGB8888) Main Display: Yes Mirror: Off Online: Yes Automatically Adjust Brightness: Yes Connection Type: Internal AMD Radeon Pro 5300M: Chipset Model: AMD Radeon Pro 5300M Type: GPU Bus: PCIe PCIe Lane Width: x8 VRAM (Total): 4 GB Vendor: AMD (0x1002) Device ID: 0x7340 Revision ID: 0x0043 ROM Revision: 113-D3220E-190 VBIOS Version: 113-D32207P1-019 Option ROM Version: 113-D32207P1-019 EFI Driver Version: 01.A1.190 Automatic Graphics Switching: Supported gMux Version: 5.0.0 Metal Family: Supported, Metal GPUFamily macOS 2
Logs
Main Process
16:15:40.939 INFO window_manager starting with app url: https://www.figma.com
File Tab
16:15:47.695 ERROR [desktop] Untrusted origin ‘null’, desktop app web bindings not initialized! [:490]
File Browser Tab
