Joseph_Cooper
April 21, 2021
FigJam connectors in Figma
  • April 21, 2021
  • 162 replies
  • 18422 views
When creating hand-off documents I like to showcase user flows by using arrows between different UI elements. I have to use plugins to create these arrows at the moment. When playing with Figjam I notice it had a connector option - this is great. I would love it if we could also have this connector option inside Figma as it would be a HUGE timesaver for hand-off.
I would like to think this would be a super easy update given that we can already edit connectors inside Figma. We just need a connector button in the toolbar like so:
Myrto
April 22, 2021
The connector lines and shapes are very helpful when creating user flows. Will these also be supported on the Figma design files? So it’s much easier to create high fidelity user flows…
111349
April 22, 2021
Came here to add same feedback. It will be very helpful. Please add this function to standart design tools.
I use plugins to add connections, but this less useful than your connections. Like this flexible 👍
Josh
Former Community Manager
April 22, 2021
Not at the moment, however you can copy and paste them from FigJam into Figma. I’ve moved this into the Feedback category and updated the title. That way others can vote and add additional comments. 🙂
Buck
April 22, 2021
+1 This is definitely something that could add a ton of value to the core Figma functionality! It needs to be accessible in normal project/design files and not just in Figjam.
Josh
April 22, 2021
While connectors aren’t officially supported in Figma they can be copy and pasted in from FigJam
Joseph_Cooper
April 22, 2021
I know. What I’m saying is it would make so much sense and be a huge time saver if we had them in Figma Design too!
Pat
April 23, 2021
Would be great also if you could anchor the connector links to any part of an image or object rather that just the sides. So that if you copy/paste a design you can anchor to buttons, menus, links on the design
Cram_Design
April 23, 2021
I completely agree. They should be some sort of smart shape like stars, polygons, and arcs.
To be very honest, I don’t understand why FigJam is a separate product, it should be the same file to work on but with a simpler toolset. Design/Prototype/Inspect/Whiteboard. Clearly a lot of hard work and intelligence was brought forth to create FigJam but it seems to me that there is a lot of overlap with Figma.
konst
April 23, 2021
I came here to suggest something similar, but I think FigJam should be an overlay over regular file, same way commenting is.
I created a thread here FigJam should also be an overlay over regular Figma pages (similar to commenting) - #2 by Karina2
Simon_Antropov
April 23, 2021
lmao, just copy this connector arrow from figjam to figma. it works there as well
