Just built a pitch deck to present to clients using Figma Slides and decided to start using object animations to add a bit of flare. I was sad to learn that Figma used the same “Start” animation choices as Powerpoint which is (1) Start on Click (2) Previous to last animation. We need more options. The biggest one is just add the same prototype prompt of “After Delay” on object animations. The other one is give us more choices then “Slide” and “Fade”. Add, the standard animations that most apps have, like spin and make 3D and more...
ENTIRELY UNRESPONSIVE SALES TEAM!!! I have reached out 5x over the last few weeks and heard nothing from your sales team. I am wanting to upgrade to enterprise. What kind of business doesn’t respond when their customer wants to give them more money????
Hello, Our team is using the new annotations feature for category, and something that would be nice as a feature add is the ability to toggle showing and hiding annotations based on category. This would enable content team members to toggle just content annotations and dev teams to toggle dev and accessibility, etc. maybe somewhere in this panel Another item of discussion is if Figma allows plugin creators to access annotations. There are a lot of really great plugins out there for annotating automatically. Envinced has a really nice one for example called Design Assistant. This tool will scan the page and then add annotations through their plugin, but as new frames on your page. Some large workflows might have hundreds of screens, so the more and more frames and such added isn’t the most valuable. Having a way for plugin creators to access annotations where their automation would apply them there instead of as frames would be really great. Thanks! -Amber
With the new update, we have a great new feature, but unfortunately, it’s not usable with our component structure. Exposing all props of a nested instance also exposes props that we don’t want in the context of the consuming component. What if we could also select which properties to expose? This would lead to a cleaner sidebar with only valid props.
We just wrapped the big announcements at Config , and we know there’s a lot to take in. This thread is your space to share reactions, ask questions, and let us know what you're excited about (or still curious about) with regard to Figma Make. Our team will be actively reading and sharing relevant takeaways with the product team. What we’d love to hear from you: What aspects are you most excited about — and why? Where do you still have questions or want more clarity? Anything that didn’t quite land for you yet? A few quick reminders: If you need help with a specific account or file issue, please get in touch with a specialist on the Support Team. A note on Community Guidelines: Posts that veer off-topic or become unproductive may be moderated to keep the focus on the product at hand. Keep feedback focused on Figma Make — this helps everyone follow along.
Hi there, quite new to Figma and have a question. Why is there a paragraph indent/empty space/tab before text in textbox? How to eliminate? Since there is no dropdown or extended view of Type, or Typography in the newest update I do not find any options to set paragraph indent. But my biggest problem right now is that it seams to be set in advance, and I don’t know what this empty space exactliy is and can’t seem to get rid of it.
I’d like to be able to choose a thumbnail (either a frame from the video, or upload a thumbnail) for an object that has Video fill. Currently Figma uses the first frame of the video as the thumbnail, and if that video starts all black, then the thumbnail is just black. It will show fine in prototype view or mirror once the video starts playing, but when you are editing it would be helpful to see a frame of the actual video so you can adjust properties of elements (e.g. colors, opacities, gradients) and see what they’ll look like composited with video.
Hi! I have a problem with a file I created and edited just this week. The file was only accessible to me and it was created in my drafts, but now I don’t see this file anywhere in my workspace, I only see it in my recents and when I open the file, I get an error that “this is an unassigned draft”. Even when I click the “request access” button, I don’t receive this request by email, as if the file was created in someone else’s space. I might have exited a workspace as well, not sure, but there are several files affected and I am unable to identify owner as well. What can I do about this?
In Figjam, when I draw a connector from one shape to another, it only wants to snap to the leading edge. Sure I can drop the arrow near to one of the other sides, but it’s not attached to that shape, so won’t follow it if I move the shape. Is this a know bug?
I’d like to insert an image into a cell in a table in FigJam so that it moves with the table as it expands and changes size. Currently, I’m just having to drag pictures around with the table as it expands which is fine for one or two images but I have many!
Hi, Context I’m helping a client design a product using the PrimeNG library. This dev library comes with a Figma library where I get components, styles, and variables. My problem I don’t know how to edit the values of variables configured in the design system so that all the components, variants, and their instances use my updated values. It’s a general question, but I’ll use one specific example below to illustrate. Example The library has a component called inputtext uses padding variables set to 10.5 horizontally and 7 vertically. I can see these variables both in the properties panel in Figma and in the Token Studio for Figma plugin. (Note that I don’t know much about this plugin and I try to use it because PrimeNG suggests it for using their system and my client’s dev team is trying to leverage it.) Padding settings in for the inputtext component (Figma and Token Studio) Padding variables in the Variables window in Figma But I can’t seem to find how to edit these values. For insta
When variables are applied components look differently (see image – the bottom component is higher and the setting is the same). Figma does this on almost every component with paddings, height even radiuses are different than designed.
Is there any way to create a line with an automatic square in the end? (See screenshot)The dropdown only allows a very limited shape variety, and unfortunately none of them is a square, which I need on a daily basis. Thanks for your help in advance :)
Hi, I thought drafts were private until you put them in a team or share with someone. I realized that every time i create a draft, who can access section is “Anyone in my team” by default. What does that mean? Do i have to change my drafts to “only me” every time i create a draft? So confusing. Thank you
My eyesight isn’t terrible, I do wear glasses, but the annotations text is too small and makes reading it quite difficult. Perhaps allow for setting the annotations text size in a user’s own seat account? Also, why on earth are annotations hidden behind a paywall? This is crazy. I can’t use them with my clients so I have to use my own annotations library instead which is obviously less convenient. Ta!
Guys i really tired of this. It’s just incredible. I just need my toolbar back
I can no longer copy one line of CSS out of dev view. I now have to use the clipboard icon to copy all the CSS and paste it into my file, then delete what I don’t need. I have added stills showing basics. I am on a Mac Sequoia 15.3.1, using Figma in Firefox Dev 139.0b5. It seems to be ok in Chrome, but that is irrelevant, unfortunately, as process is dependent on Firefox Dev.
Find answers, learn more.
