the prompt for changing the component width, doesn't work in Figma make, is there any prompt structure, that works?
The system sent me an annual invoice, but our team has frequent personnel changes, so an annual billing plan is not suitable for us. Also, we don’t need 12 design seats. I would like to switch to a monthly billing plan, but I couldn’t find a way to do this on my own, so I contacted customer support via email. However, I still haven’t received any help or resolution so far.
I am working with Figma for about 3 years and it is a wonderful software. Speed used to be awesome in the beginning. It changed after a while and now it is really a pain to open files, select frames and resize areas. It starts blocking my work. You read always “Empty the cache...” I did but no change. Please dear Figma team realize that there is a problem that needs your attention.
Hello,I am new to Figma and have encountered a problem: one of my devices does not have a Prototype panel.I have two devices: a home device with a Prototype tab near the Design tab and a work device without it. Even when I go to Figma > View > Panels, I don't see the «Open prototype panel» button, which is available on my home device.I tried reinstalling Figma, but that didn't help.This button was there previously, before the last update
Trying to walk through setting up something using Gemini but it ends up stuck on this ‘auto layout’ business. I need to create a section in figma then nest a frame inside that section, in which to place content. the section does not have this auto layout attribute. does the frame within this section: need to be sized to fit the width and height of the section? need to have layout settings placed upon it in order to automatically fill the width of the parent section? need padding set on it? please do not simply link to other content. any assistance specific to this question will be greatly appreciated.
Hello! Wondering if anyone can steer me in the right direction. I’ve been using Google Sheets Sync in figma for over a year now, suddenly is stopped working and is giving me the message “There was an error fetching. Try again later” I didn’t change anything since the last time I used it, i’ve tried restricting the google sheet and re-opening it up. I use this to create labels for my orders and it’s extremely helpful. Thank you.
got this error few times, and when i hit try again or close it, nothing happen
It seems very unusual to publish a code generation feature without any kind of mechanism for export to version control. While I’ve been testing figma make and enjoyed the result, i’m having to consider moving to alternatives like lovable because of the benefits of simpler integration with version control. Will we be able to link our figma make projects to a github repository in future? an alternative approach would be integration with the figma for VSCode extension.
Hello there! I am new to coding, figma make, and github. I have a prototype designed in Figma Make. I am wondering if anyone can help me save my work to github? Starting from having a published prototype to commit work to GitHub. Here’s what I’ve done so far. 1. Created a New GitHub repository for my prototype I created in Figma Make2. Published my Figma Make prototype3. Downloaded the code to a folder on my local computer I appreciate any help! This is all very exciting stuff.
i’m trying to copy an image from pintrest into an instance and it is not fitting into the instance frame
I’m encountering some issues with Figma; regardless of whether the file has many pages or few, the operations are very laggy. I’ve tried changing my network and using a VPN, but neither has made a significant difference. What should I try now?
Find answers, learn more.
