Change variant of a component from a different component
Bez1
I would really like to understand how it is possible, if at all to control one component from a completely different one.
For example, I have a button that I want to change the variant of a completely different component. the button can’t be in the same component or set of components.
I read on conditional statements and interactive components, but this is not at all what I am looking for even though some people said this is the solution in other older posts I read.
All i want is that when clicking on component A, it will change component B variant.
Is this possible already or still not?
Best answer by tank666
Variables and advanced prototyping is what you need. And it’s already available now. Just create a variable and bind it to the property in the instance whose variant you want to change. Then add a click interaction on some other object, in which set up a “Set variable” action to change the value of the variable.
  • 4868 replies
  • July 25, 2023
Bez1
  • 9 replies
  • July 25, 2023
Thank you! I google and googled, and nothing came up that explined that clearly enough, , funny how your 3 sentences made it clear to me finally!
Do you know though if it’s possible to use the smart animate feature in conjunction with the conditional statements?
thanks again!
  • 4868 replies
  • July 25, 2023
Yes, of course, some actions inside conditional blocks support the “Smart animate” feature.
Bez1
  • 9 replies
  • July 26, 2023
Hey, do you know by any chance what actions are supported with animations?
The only one I could see were supported are the ones that are already set on same component / component set, so if you use a variable to trigger a different component, I could not see any animation support. Am I missing something?
Many thanks! again
  • 4868 replies
  • July 26, 2023
Smart animate is supported in the following actions:
  • Navigate to;
  • Change to;
  • Scroll to;
  • Open overlay;
  • Swap overlay.
Bez1
  • 9 replies
  • July 26, 2023
So it works only on the same component,
Kind of make the whole set variable useless for a lot of cases.
Would be nice to have just a simple trigger to another component the way you can do on the same component instead of the whole variable thing.
I feel like it’s a very convoluted way of doing things and this could have been solved much more elegantly, but it is what it is. Shame.
Thank you regardless.
  • August 25, 2023
