On Figma UI, it’s easy to set a hyperlink to an instance node by right click “Copy/Paste as“ > “Copy link“. However, I got an error when doing the same thing through plugin API.
The document only says “the (target) node cannot be a sublayer of an instance”. But how about target to that exact instance?
I’m wondering why they are inconsistent. Is there any concern behind?
Does anyone know the answer or the mechanics behind?
Or any Figma employee has been looking into this?
Is there any solution or workaround?
I’ve tried to copy a text with links inside from one TextNode to another.
Though getRangeHyperlink gives a range split, setRangeHyperlink throws exactly the same error “Invalid hyperlink node reference. Hyperlink target node must be a page or a frame” in case the source link type is “NODE”. In case link type is “URL” no error appears.
Update:
The error appears when target node is ‘InstanceNode’
This also happens to us when the target node is a Main Component.
Basically the documentation only says “cannot be a sublayer of an instance”.
And the error says “it must be a page or a frame”.
Something’s off.
Upvote to fix this bug in the API.
