Can't set hyperlink to page node with plugin
shaina
Within the UI its quite simple to copy a link to a page within a file, and add it as a hypertext link to any text. But when trying to do so with the plugin APIs, I get an error that it must be a frame node.
Why is there this inconsistency?
Example below of a text node that’s set to a page node via the UI. Trying to link to the same page with the API fails
Michael_Ehrmann
Same here, this would be awesome to get fixed.
Even when setting a link to the URL manually this leads to the same Error.
When using “http://” protocol instead of “https://” it works, but will open in a separate tab.
Brian26
  • July 8, 2022
The same issue, it works on UI if I can paste the link of a component or an instance to the text, but I cannot do it on API.
Sidney
  • November 25, 2022
Same issue here with trying to link to sections
  • 4873 replies
  • December 9, 2022
