Good afternoon)) Pop-up is configured in prototype. When you hover over the buttons at the bottom, the pop-up closes, although there is a Close button at the top right. How to remove the pop-up closure. Also, one of the frames with information inside the pop-up is hidden. How can I fix this?
Hi, I recently logged into my Figma and it shows I’m on the Education plan but I'm not sure what is the expiration date. I read that it lasts for 2 years, but is it possible to know the exact date as I don’t want to suddenly get logged out from my school project while I'm in the midst of it. I tried asking chatbot and it says I’m on a starter plan. So I’m a bit confuse and unsure.
I received an email last week saying I needed to renew my Educators plan and that some information was required, I sent everything and was automatically approved. The problem is I still have my files on view only mode and cant edit anything (even if it allows me to ask for editing permissions to the owner -which is myself and can’t give permissions to myself.-) Help please!
This is odd behaviour in my mind!When i select an item and use the scale tool, it makes the new size its default 1x when i reselect that element. Example: I select an image, set the scale to 1.2x, go about my business, return because i want to return that item to it’s initial 1x scale, increase or decrease it. The new size has now been set as its default 1x. and now i have to do math! Why wont it just remember that i set it to 1.2x? This behaviour is weird and makes me wanna use scale less!
always loading, cannot be exported successfully, IM waiting for a whole day, Its still loading, and i cant find the library in figma make:
Hi everyone! Why “accesibility settings” are not available for Figma Slides too? It would be very useful, also to download accessible pdf. Please add it soon. Thank you 🙂
I’m trying to create the text effect in this image. The odometer’s text wraps around the circle very nicely. Right now I have to use a plugin, but I lose the ability to edit the text afterwards and there is no preview so I have to try a few times to get the text to wrap nicely. Sketch had a feature where if you dragged a text on top of a path it would snap to it and would follow the path. A similar feature (perhaps with a better implementation) would be very welcome on Figma.
I’d like to be able to choose a thumbnail (either a frame from the video, or upload a thumbnail) for an object that has Video fill. Currently Figma uses the first frame of the video as the thumbnail, and if that video starts all black, then the thumbnail is just black. It will show fine in prototype view or mirror once the video starts playing, but when you are editing it would be helpful to see a frame of the actual video so you can adjust properties of elements (e.g. colors, opacities, gradients) and see what they’ll look like composited with video.
The recently introduced fill patterns do not seem to be correctly saved in styles: They are not editable (cannot select a new pattern object, and the toolbar does not show the pattern tab) When exported from a library, using them in another file results in displaying dots (presumably the default pattern)
Hi Figma community. I would like to know if any of you uses a way to make changelogs automatically that update once there has been a change in the components (in our design system library) and that it can detect the type of change that has been done, the name of the component, date. If you know any plugin that can work for this please let me know!
Hi Figma community. I would like to know if there’s a possibility to make automative changelogs in figma that update automatically once there has been a change in the components (in our design system library) and that it can detect the type of change that has been done, the name of the component, date. If you know any plugin that can work for this please let me know!
I have master components in molecules and organisms, the problem is that we put multiple booleans for different rows for example and now we want to edit content them with AI or manually as group. Figma highlights the connected booleans but it does not allow to select them with one click, Does anyone know a way? I was surprised that double click on the boolean title did not select them. PS: Select all with same properties does not work, because it select all the columns as they are same component but used in different columns
While exporting to pptx, fonts change, alignement get mess up, rotations reset… Is there a way to make it work?
Hi all. I have a couple of frames that have placed image in. I want to export as .svg format. I can see the image in the preview and on the preview of the .svg. But when I open the .svg in adobe illustrator the image isnt there and just should a blank box… Any ideas? It worked fine in sketch before.
Find answers, learn more.
