jamie_sigler
Oct 20, 2022 2:19 PM UTC
Placed images not exporting in .svg
Hi all. I have a couple of frames that have placed image in.
I want to export as .svg format.
I can see the image in the preview and on the preview of the .svg. But when I open the .svg in adobe illustrator the image isnt there and just should a blank box…
Any ideas? It worked fine in sketch before.
Gayani_S
Gayani_SSolution
Jul 11, 2025 10:29 AM UTC
Hey everyone! I’ve followed up on the support ticket I’ve created for the community member who previously flagged this.
The team recommends as a workaround, to export the design as a PDF instead, which you can then open and resize in Photoshop without the same issues. It might also be worth reaching out to Adobe to see if they have additional insights or suggestions.
That said, if you’re experiencing this and would like our support team to take a closer look at your specific case, feel free to reach out to us directly via this form.
We really appreciate your patience and the time you’ve taken to report this!
ThomasHallgren
Oct 20, 2022 4:07 PM UTC
SVG does not do a good job supporting images. Try adding the image in Illustrator.
ak12
Jul 4, 2024 9:05 AM UTC
If you encounter this problem today, will you get the same answer, or is there a new way?
Gayani_S
Jul 24, 2024 3:32 PM UTC
Hey @ak12, thank you for reaching out!
I can create support ticket on your behalf so our support team can take a look at your file. Before that can you answer me the following question:
Are you having trouble opening up the SVG files in chrome or another application?
Gayani
ak12
Jul 25, 2024 6:35 AM UTC
@Gayani_S, Thanks for reaching out to me too.
Yes. The SVG files isn’t trouble opens and works in other applications.
photoshop and chrome.
Then I looked again and realized that some computers were opening the file and some were not.
Gayani_S
Jul 26, 2024 2:58 PM UTC
Thanks for the information @ak12, can you give me an examples on what devices the SVG is opening correctly and and on what devices it is not?
I would need this information to double check internally with the team.
Thank you in advance!
Jul 31, 2024 12:21 PM UTC
really nice, the question is from 2022, and 2 years later it’s still here. Ok I have the same problem, I export the frame with embed image in Figma to svg, open it in AI and the image is gone.
About a month ago I must use export with pdf, and the image is still show up in AI. But now it’s gone too with pdf export.
Please check what is happen
Gayani_S
Aug 2, 2024 8:21 AM UTC
Hey @Truong_Tran, I think your sentiment is valid when seeing that this issue is still ongoing, hope to see this resolved soon too!
I’ve created a support ticket on your behalf, so our team can investigate further on this. Your ticket number is #1083031, for reference.
Please do share a screen recording with the team, so they can investigate further.
Our support team usually takes up to 24 hours to reply back to emails - tends to be quicker than that in normal circumstances. However, please be aware that we are facing increased contact volume so there might be a delay.
Gayani
Thao_Le1
Aug 13, 2024 4:01 AM UTC
I’m encountering the same problem. Any Figma frames containing images result in missing images after exporting as SVG and importing into Adobe Illustrator. It’s frustrated situation.
Gayani_S
Aug 13, 2024 12:49 PM UTC
Hey @Thao_Le1, thank you for reaching out!
Can you please share a video recording of the issue you’re encountering with a description/explanation? I’d like to see if you are able to export the SVG successfully in Figma and only have issues when importing the SVG in Adobe Illustrator.
Rob29
Oct 29, 2024 12:47 AM UTC
Im having this problem as well. Any possible solution coming?
