Jens_Nielsen
Jun 25, 2025 2:17 PM UTC
Doesn't remember scale value when reselecting element
This is odd behaviour in my mind!
When i select an item and use the scale tool, it makes the new size its default 1x when i reselect that element.
Example:
I select an image, set the scale to 1.2x, go about my business, return because i want to return that item to it’s initial 1x scale, increase or decrease it. The new size has now been set as its default 1x. and now i have to do math!
Why wont it just remember that i set it to 1.2x? This behaviour is weird and makes me wanna use scale less!
Jun 26, 2025 5:45 AM UTC
Hi ​@Jens_Nielsen,
I looked into this internally, and it seems like the scale multiplier does reset when you exit the scale tool. So, the behavior you're describing is actually how it's currently designed.
I'll go ahead and pass your feedback along to our team as a feature request for their consideration. While we can't promise specific changes, we really appreciate you bringing your thoughts to our attention.
Thanks for helping us make Figma better!
Jens_Nielsen
Jun 26, 2025 10:17 AM UTC
Thanks for passing it on. It is especially annoying when you are doing prototypes and animations where scaling is often used.
Jens_Nielsen
Oct 15, 2025 6:34 AM UTC
Hi ​@Jens_Nielsen,
Any update on this issue?
Oct 17, 2025 2:28 AM UTC
Wish I had an update to share, but there isn’t any information available at this time.
If more community members share similar feedback, it’s likely to gain higher priority, so let’s see if others in the community feel the same way.
In the meantime, please keep an eye on our Blog and Release Notes for future updates.
