Hugo Canis
Jun 26, 2025 7:35 AM UTC
Issues exporting slides to pptx
While exporting to pptx, fonts change, alignement get mess up, rotations reset…
Is there a way to make it work?
Gayani_S
Jun 26, 2025 12:51 PM UTC
Hey ​@Hugo Canis, thanks for reaching out!
As A disclaimer, there are some limitations when exporting slides to .pptx which might have led to this behaviour:
  • Fonts: If a font is not available in PowerPoint, the text layer will be updated to use the default PowerPoint font
  • Interactive elements and code blocks:Live interactions and code blocks will be exported as static images
  • Gradient fills: Gradient fills will be changed to solid color fills
I can get you connected to our support team, so they can take a closer look as well! For this I’d need a screen recording I can share with the team so the they can start troubleshooting with you. Please include the whole window for the screen recording, with the properties and layers panels in view and relevant layers expanded, and select any layers you're having trouble with so we can check any relevant settings. Support uses these videos to try and reproduce the issue in our own files and so showing all steps needed to reproduce the behaviour is helpful.
Please let me know if you’d like to get connected to our support team.
ksn
Sep 26, 2025 4:54 PM UTC
Hello! I will be closing this topic. If anyone comes across this post and has a similar issue, please create a new topic so we may help you further. Thank you!! 😄
