Temporarily hiding selection outlines
Show first post
SLT-UX
  • Active Member
  • April 3, 2024
Ok I see.
Yeah, having to do all that would defeat the purpose, as the idea is to stay in flow, with minimal effort/disruption for the user.
If a plugin cannot operate in the background in Figma, one would always have to launch it and close it and launch it again… which is too much work.
To answer your question: It would be ideal if when the outlines, handles, etc… are hidden, the selection could still be edited.
But if not, at least we would be able to easily hide the selection outlines, handles, etc. , see how things look, and then edit again once the selection outlines, handles, etc. are showing again. We definitely don’t want to have to manually re-select things again.
I found a video on Youtube describing this feature (in Adobe Illustrator):
Illustrator Fashion Design Shortcuts | Hide Selected Edges|Illustrator Fashion Design Shortcuts | Hide Selected Edges
  • April 3, 2024
Yeah let’s hope they add it to Figma
In Illustrator it’s command+h. c’mon man.
Tom_Auger2
Getting sick of always having to deselect stuff to see the visual impact of a change, eg to the stroke of an element. CTRL/CMD-H let’s gooo!
Knomary.Production
+1 for Ctrl(Cmd)+H comand for temp hiding bounding boxes and outlines in Figma
Neal_Derek_Lawson1
Yes looking for this as well, like Illustrators cmd H.
Tom_Auger2
Interestingly, I just noted that if you nudge an element using the arrow keys, the selection border goes away for a short period of time. So maybe that’s a workaround? Nudge left then nudge right? Meh…
SLT-UX
  • Active Member
  • June 14, 2024
Yep that’s what we have to do today -constantly nudge back and forth - to keep the selection outlines hidden. The problem is that when working on stuff especially icons, nudging back and forth prevents you from seeing your design as it should look.
Come on Figma Team this really should not be that difficult to implement??
@dvaliao maybe you can “nudge” this issue up to the team (pun intended)
  • June 14, 2024
An error occurred: seems unclear, is it a complete sentence?emphasized text
Phillip_Wildhirt
+1 for this one please
Filipe_Ligabue
Ian8
  • September 11, 2024
Really? Doesn’t this famous Figma have this function?
I started using it an hour ago and have already found a couple of missing features that already make me want to go back to Illustrator.
How comfortable should one be searching for the right font for a logo (e.g.) with the constant distraction of selection outline?
Romanr
  • October 13, 2024
+1 for the tenth time since 2019.
Such a simple, must-have productivity feature request has been ignored for five years, and considering the rate at which other features are added, it is unlikely to be implemented at all. Because Figma is not created by designers, it is not created for designers. It is made by business people for investors.
Jeremias_Santos
I need this urgently to get work done. C’mon, guys, it shouldn’t take you more than a few minutes! Please 🥹
niran182
  • February 24, 2025
A Must!
nathan9
  • April 8, 2025
I cannot believe they still haven't implemented this, it’s a little frustrating to be honest.
Currently, I'm changing the blending mode of an image fill, but I can't see anything because I can't hide the tile resizer. So seeing if I like a blending mode is a 5-step process. Forget A/B’ing.
nathan9
  • April 9, 2025
Even if you do that, any red object alignment guides still appear. So if your text is centered or otherwise aligned with something, there will be a giant red line through it, even if you're nudging it around. Granted, this doesn't happen as often as it sounds.
That said, if we can’t have this feature, I would still appreciate a preference that lets us change how many seconds it takes for the selection guides to come back. And then, if you mouseover the selection, the selection guides can come back immediately. (Usually I’m making fine adjustments or A/B’ing with the keyboard — if I move the mouse I’m ready to interact with the selection outline, which you can’t do with the keyboard.)
George Kent
+1
yes please Figma peeps, this would be incredibly useful.
some guy
  • May 15, 2025
pwetty pwease can we have dis figma
nathan9
  • May 24, 2025
I’d love for someone on the team to chip in here, but they’re probably working on one of the new projects.
but what’s the point of having a forum if no one from the team reads it…
