Sergio10
Oct 3, 2023 2:39 PM UTC
Open Figma links inside the app
It would be great to have the ability to open a shared Figma link somewhere in the app. Maybe on the home page.
WHY?
The working process implies sharing the content. If it’s one team, they can easily tag each other in Comments and be happy.
However, we may also share the Figma links in such places as JIRA or other.
https://www.figma.com/file/________________________
In that case, when you click on the link in a browser, you have it opened in a browser. Yes, you can switch using the ‘open in app’ button. But it’s not so convenient when you have a bunch of links.
I’d propose having an input field on the home page, where we could paste the link(s), and they would have been opened in a new tab(s).
tank666
Oct 3, 2023 4:00 PM UTC
You can also open a file in an application from the clipboard.
Guthrie
Oct 12, 2023 12:43 PM UTC
That option has stopped working in Chrome.
Edit:
I managed to fix it by opening a link in Safari and then it showed me the open in Figma message ‘Open in Desktop app’ option. I selected the open in app options with always box checked.
Now when I click on the same link in Chrome it redirects as it used to the desktop top app.
Some Mac OS Sonoma issue I suspect.
Jan 2, 2024 7:26 PM UTC
The Safari trick was required for me as well.
  • Open link in Safari
  • Login to Figma
  • Close and reopen the desktop app
  • Refresh the Safari page, and I received the prompt to open in Figma app
  • Approved, then verified that opening the link in Chrome successfully opens the app now
David_da_Silva_Contin
Aug 2, 2024 11:37 AM UTC
Another option is to replace https://www.figma.com with figma://.
This works for prototypes too.
Elisa20
Oct 18, 2024 12:14 PM UTC
Amazing trick! Thanks a lot 🙌
Paty Paredes
Feb 18, 2025 9:54 AM UTC
None of the options commented here work for me ☹️
I already have the desktop app installed, but it still appears the option “Get desktop app”. I have already tried to uninstall and install again but nothing changes.
This is what appears in Chrome (cache cleaned already)
and this is in Safari (cache cleaned also) - doesn’t even appear the option to open links in desktop app:
Can someone help?
Thanks a lot!
Feb 19, 2025 12:16 AM UTC
Hey ​@Paty Paredes, thanks for reaching out!
Is your desktop app up to date? You can check from Figma > Check for Updates…
If that doesn’t help, typically users will see the Get desktop app setting instead of Open in desktop app, if they’re not logged into the same account in browser and within the desktop app. Be sure that you're logged in to the same account. And if you haven’t already, I’d also recommend clearing your desktop app’s cache and restarting your laptop.
Paty Paredes
Feb 19, 2025 9:12 AM UTC
Hey ​@dvaliao,
The app was updated and I was logged in into the same account in the browser and in the app, so I tried clearing the desktop app’s cache and restarting the laptop and it worked!! Thank you so much.
claud_gp
Sep 8, 2025 2:52 PM UTC
This worked for me...
You can replace a part of a URL in Chrome using a line of javascript which will replace https://www.figma.com with figma://
Using a Bookmarklet
A bookmarklet is a bookmark that contains JavaScript code instead of a URL. When you click it, the code runs on the current page. This is a quick and effective way to perform simple URL manipulations.
Steps:
  1. Open your bookmarks bar (if it's not visible, press Ctrl+Shift+B or Cmd+Shift+B on Mac).
  2. Right-click on the bookmarks bar and select Add page... or Add bookmark.
  3. Give the bookmark a name, like "Figma URL Fix".
  4. In the URL field, paste the following code:
    JavaScript
    javascript:void(window.location.href = window.location.href.replace('https://www.figma.com', 'figma://'));
  5. Click Save.
Now, whenever you are on a https://www.figma.com URL, you can click this bookmarklet to automatically replace the start of the URL and redirect to the figma:// version. .
