Nazim_Can_Tunc
Jan 31, 2021 7:11 PM UTC
Multiple Flows Should Have Different Device Frames
It would be great if we could select different device frames for each flow. This would give huge benefits to those who design responsive websites side by side.
Olli-Pekka_Jauhiainen
Aug 22, 2021 7:59 AM UTC
This is a must-have feature!
Diego_Ibanez
Aug 26, 2021 5:57 PM UTC
I found an alternate way of showing responsive prototypes. Here is how:
  1. Select custom size from the device list (all the way at the bottom)
  2. Set the max width and height of your screens
  3. Play prototype and select the different flows. In my case mobile, tablet, desktop and watch the screen adjust to each flow screen size.
This might not be the ideal solution but for now it works for me. Hope you find it useful 🙂
Here is a screen capture
figma-responsive-prototype
Kai_Magnus
Sep 7, 2021 11:20 AM UTC
Yes please, I come across this issue every few weeks and there’s no satisfying solution really.
Fabrice
Sep 18, 2021 3:52 AM UTC
Same need here! Browsing ALL the flows on my file regardless of the page they’re defined on.
Marcio_Gutheil
Sep 21, 2021 3:05 AM UTC
A must have feature.
Alyssa_Maac
Sep 27, 2021 11:11 AM UTC
I have an alternative solution as well.
  1. Add a " Flow starting point " to each of the frame that have different frame sizes (ie. the mobile will have it’s own starting point, the desktop will have its own starting point).
  2. Once done, click outside the frame anywhere on the canvas to unselect any frame.
  3. Then under " Prototype " change " Device" to " Presentation (Fill) "
  4. Now preview your designs. The preview size will follow the frame size.
Joel2
Oct 6, 2021 3:19 PM UTC
The alternatives arent good enough because we literally need different prototype devices for different flows especially when it is screen size specific so that scrolling would work properly.
I’m actually very surprised that this feature isnt supported.
Giorgos_Domouchtsidis
Oct 7, 2021 3:11 PM UTC
Yes please!
Williams_Chris_LTPD
Oct 18, 2021 5:54 AM UTC
Yes please.
A prototype example which would benefit from this:
Web-based Dashboard then jumps to a Mobile Device which shows changes that were set on the Web Dashboard.
Thank you Figma.
Margot_Gabel
Oct 29, 2021 1:43 PM UTC
Surprised to see that this has not been updated in the last Prototype update 😦
Using Figma since 2018.
