MayaShendelman
Jun 9, 2021 11:04 AM UTC
Keep Comments pinned to design elements (including nested)
When i move my design elements/frames/etc., I expect all the pinned comments to move with them – but they don’t. instead i’m left with a bunch of floating comments (that are not attached to anything), which requires me to manually re-read each comment and move it again to its correct place. this is frustrating and time consuming. but what’s worse is when another user forgets to move the comments after they move the design elements, so when i return to the Figma file it’s very difficult to decipher the floating comments because they are not pinned to anything so i have no idea what they’re referring to. please keep Comments pinned to design elements (so moving design elements automatically moves comments).
James_Lytle2
Apr 19, 2022 3:31 PM UTC
In a FigJam I noticed the comment state highlights objects as you hover over them, and I wondered if that meant your comment would get stuck to that object.
I imagine this could serve lots of potential purposes, but the first practical one is that when objects get moved around, the comment pointers could stay pointing at the original thing.
Other extended ideas:
  • When the object is deleted, the thread is resolved by default.
  • When the object changes, that could be reflected somehow in the thread, so the discussion evolves.
  • Discussion can now be tied to all kinds of text, styling, etc…go wild on your analytics/insights…but what is useful?!
Mostly for starters I want comment locations to stay relevant in the flow of working.
JanKragh
Apr 20, 2022 11:25 AM UTC
Hi James,
I think that the object/comment used to be like your describe it: when moving the object the comment would stay on the same canvas-position.
But I just checked right now: windows Figma app 112.2: now when I move the object, the comments follow, both Design/FigJam. Was this just fixed maybe?
Lin_Leslie
May 2, 2022 9:30 PM UTC
Up voting this one. Still a big issue for me!
Jesper_T_Hansen
May 4, 2022 8:43 AM UTC
Same here. Would love to have an option to pin comments to elements - suggestion, if deleting the element it would be nice to either:
a. Keep the comment per default but make it floating with a note saying something like “pinned element deleted”
b. Get a dialogue with the option to either keep the comment (floating) or delete it
Maria_Teresa_Ramos
May 12, 2022 1:14 PM UTC
Did this get resolved? I am still experiencing this and is so time consuming.
Christian_Davis1
May 19, 2022 4:37 PM UTC
This isn’t working for me. Can you explain how this is done?
zlouden
Jun 22, 2022 1:23 AM UTC
Has there been any resolution on this? Incredibly annoying.
Ryan_Beymer
Jun 28, 2022 7:44 PM UTC
While this might work at a top level frame, I like to have have my frames in auto layout to keep everything tidy.
This breaks the functionality of “pinning” to a frame so I end up ungrouping to have the pinning functionality at a high level.
However the issue bubbles up in frames that have auto layout and things shifting around alot.
Can we pin to a frame or group regardless if it’s a parent or not? Pretty pls?
chuanyi.qin
Jun 30, 2022 4:47 PM UTC
a couple of days ago, my comments were pinned to the frames, I thought the issue was solved which was great. But today the comments are no longer pinned. I wish I knew what I did before.
Lucrecia_Garino
Jul 4, 2022 9:27 AM UTC
sometimes it works misteriously, sometimes it doesn’t
