Why can’t I paste an image directly into an image component in Figma anymore?
Show first post
Finn_BR_Studio
Same Problem
Please fix
@Figma_Support
Aaron Jackson
I’m experiencing the same problem along with my team. This is an insane degradation killing our workflow.
This thread is marked as ‘Solved’ but this is far from solved.
Please fix asap 🙏🏼
Matthew_Pearson
Hi, I’ve been struggling with this on and off. But yesterday I found a way!
With an image copied on your clipboard. Locate your image fill, in it’s figma frame, but don’t click the image fill:
Then click just to the left of the grey lozenge around the fill image preview:
My cursor clicked where the red dot is.
This selects the fill, now CTRL V or CMD V and the image from your clipboard is added as a fill.
It’s quite tricky to click this small area, but it’s got me where I want, I think figma could improve this.
Dan Gramescu
Yeah still doesn’t work… Tried everything here but no luck
Gayani_S
  • 2301 replies
  • July 28, 2025
Hey everyone! Thank you for flagging this again, we hear you! Our team is actively looking into the issue with copying and pasting image fills. We know this is a workflow many of you rely on, and we really appreciate your patience while we investigate. I’ll keep you posted here as soon as we have an update. Thanks again for bringing this to our attention and for your continued feedback!
Tom Reem
  • Figmate
  • 396 replies
  • August 5, 2025
Hi everyone, stepping in for ​@Gayani_S with a quick update from our side: Our engineering team pushed a fix to production that should resolve this issue. ✅
💡 If you haven’t already, try giving the tab you’re working in a quick refresh → copy/paste functionality should now behave as expected.
Thanks again for your patience while we worked to get this resolved. Let us know how it goes, and if any questions remain.
KelseyONeill
  • 15 replies
  • August 6, 2025
I really hope this is a bug and not a “feature”. Hope it gets fixed soon, cause I hate it. I copy paste into frames so much.
Something I havnt seen others mention, is when I paste an image directly into figma from somewhere else, it puts in in a new frame, not in the frame I already have selected. I know selecting the thumbnail works, but I still have to paste the image in figma, copy the thumbnail from the new frame, then select the frame where I want it and paste there.
Pieter_Beukman
A very frustrating issue was introduced here. This used to work so much better before.
I closed the Figma desktop app and reopened all my tabs as requested but the issue is still there.
I often start with a frame, apply an image to it, add rounded corners, outlines, shadow etc, duplicate it to then replace only frame fill with other images that I copy from the clipboard from the web. This flow doesn’t work anymore at all. Previously you could open the image fill pane, press command V and only the image would be replaced by the one in the clipboard. Does not work anymore. Now you need to paste the image into the canvas, hit copy style shortcut, click the new frame, hit paste style shortcut but that then overrides the rounded corners, outline etc. Such a simple timesaver ease-of-use action is now very frustrating.
Gayani_S
  • 2301 replies
  • August 14, 2025
Hi ​@KelseyONeill and ​@Pieter_Beukman, thank you for taking the time to share your experiences!
Our engineering team has already pushed a fix to production that should have resolved this, but since you’re still running into the issue, I’ve flagged your reports with them so we can dig in further. I’ll follow up here as soon as I hear back from the team.
Appreciate your patience in the meantime!
Pieter_Beukman
Hi there. Any update on this ​@Gayani_S? I am still running into this workflow issue which makes it very very difficult to quickly input real images into existing UI frames.
extrakerned
  • August 26, 2025
This broke again today.
Jaszkin-Man_Jakub
It also does not work for our team.
I have an image in clipboard, copied from the web and pasting it into the frame (in the instance of card component) does nothing…
I have to paste it somewhere on the canvas, then use the hack from above (click on the left side of image thumbnail → Cmd-C → select image in the instance → left side of the thumbnail → Cmd-V) and it is quite infuriating 😡
Jaszkin-Man_Jakub
We’ve found a workaround which is quite absurd…
You can:
click on the image thumbnail → Upload from computer → Cancel → Cmd-V → voilà! 🤣
Jazz_Ernest
  • 5 replies
  • August 27, 2025
Absolutely crazy that this is broken again, and is such a key workflow for so many of us
Olly_the_Designer
Don’t think they have because it’s not working.
Gayani_S
  • 2301 replies
  • September 4, 2025
Hey everyone, I completely hear your frustration on this, and I’m really sorry that you’re still running into the issue. I’ve flagged this again with the team and I’m actively pushing it on my side so they see the urgency. As soon as I hear back with any updates, I’ll share them here right away. Really appreciate your patience while we work on this.
Sky123
  • September 4, 2025
1
Sky123
  • September 4, 2025
sdf
