"Variable value doesn't map to variant"
Leander_Nelissen
I have been playing around with variable prototyping, but sometimes when I assign a variable to a variant, I get this popup. Does anybody know what this means and how I can fix it?
ksn
  • 1687 replies
  • December 1, 2023
@Leander_Nelissen hmm – are you able to share a copy of this particular file your screenshot is from? I think support would be best to answer this after looking. I’m not sure what’s triggering that message directly on my end.
You can create a ticket here, and someone will review + let you know what’s going on: https://help.figma.com/hc/en-us/requests/new?ticket_form_id=360001744374
I found this same issue.
It was caused by the boolean property in the variant (“Show” in your case) being set to “Yes”/“No”, but the boolean variable is usually “True”/“False” - so go ahead into the Keyboard and make sure you use True / False
Atiyah_Thomas
Was this issue resolved having the same issue.
Leander_Nelissen
Yes, just use True/false instead of yes/no
Sakky_Baral
Lifesaver!!!
Zohar_Uziely
I used boolean variable, but it still doesn’t work (it have to be true/false, I have no option to change it but it still doesn’t work)
variables:
in the component:
Gayani_S
  • 2111 replies
  • June 10, 2024
Hey everyone, I am checking this internally with the team. Would appreciate it, if anyone is able to provide a direct link to the file and invite support-share@figma.com with “can edit” permission so we can look into this further? Note that users with @figma.com emails on your team do not count towards your billing.
Thanks!
@Zohar_Uziely True/False should be set for the property in the main component (in your case for property “Selected”).
It seems that Figma can convert any variant with values (yes/no or on/off or smth similar) into a boolean property, but keeps under the hood these initially provided text strings(eg yes/no) and when you try to match Boolean variable and such a boolean property of the component, looks like Figma under the hood still tries to match text strings and for Boolean variable it’s a True/False and for your component it’s Yes/No(or other wording) - and this is the place where the issue happens
Zohar_Uziely
Great answer! Thank you!!
Niharika_Bankapure
Here’s the solution to this issue: In the main component, ensure the property is set as true or false, not as on or off. For example, use selected=true or selected=false. This should align with the local variable, which should also be a string: “true” or “false”.
Bauke_Schildt
@PaulUX Found a workaround for when you can’t just change the component (for example, when it’s coming from a library):
You need to create a new string variable when applying a variable (Click on the + in the popover)
https://forum.figma.com/report-a-problem-6/no-yes-variants-after-being-automatically-converted-to-boolean-are-still-treated-as-string-stopping-boolean-variables-binded-to-an-instance-from-working-16352?postid=144002#post144002
