Unable to see fix position for my nav-bar
Please search for existing topics before posting! Press 🔍 at the upper right to search.
dennsi
  • Active Member
  • 257 replies
  • April 20, 2023
Thank you for answering. Looks like my nav bar is still not fixed by following the article’s directions. I may have another issue. I would appreciate it if someone chimes in.
dennsi
  • Active Member
  • 257 replies
  • April 20, 2023
Could you share a test file to examine?
These are the frames I am working with. When I play Prototype my nav bar is not locked in modules as the user views the content of modules and it disappears. Any help would be appreciated.
deeban
  • August 7, 2024
how to zoom in sidebar panel
Michael_DeBellis
You have probably figured out the answer by now but I had the same problem. You need to click on the widget that you don’t want to scroll. Then go to the prototype tab and under “Scrolling Behavior” there will be an option that says “Position” and it is a drop down menu and one of the options is “Fixed”. Do that for any widget you want to stay fixed and not to scroll. IMO, it is unacceptable that the intro tutorial is not consistent with the latest UI. It would take someone perhaps 1-2 hours to update the intro documentation. Instead you make every new user waste a lot of time hunting around for the correct option. It really gives a new user (especially someone like me who has never used a tool like this) a bad perception of the tool.
