Will_Nandi
May 5, 2021 10:48 PM UTC
Export losing quality even using PNG and 2X higher
I am trying to use Figma as my main software to produce my designs.
But my frames are being exported with a bad resolution from Figma.
Exporting as PNG and even using 2X is not getting the full resolution as I see on Figma.
Anyone with the same issue?
Power Member
Nov 19, 2021 10:53 PM UTC
And the original file link? If this is the result, there needs to be a way to compare it to something.
Martam29
Dec 8, 2021 11:11 PM UTC
literally same! I´m quite new to Figma and didn´t even think this would be an issue since it looked so good while making everything! And now I need to have these images like tomorrow for a project but don´t have them bc of this really bad quality…
This image is when exported at normal quality
Is there anyway to export the frames at an actually acceptable quality (300dpi, to print it)
@Gleb You are always asking about the original file link, how do i get it? (or is it just copying it from the browser?) And could i send it privately instead of it being public? Thanks!
Martam29
This one is at x2, but looks just as pixelated as the normal one.
Power Member
Dec 8, 2021 11:38 PM UTC
Just copy the link from the browser.
Power Member
Dec 9, 2021 12:35 AM UTC
I just tried exporting from your file and I don’t see any issues with it. So it’s more likely the problem of how you are viewing the exported file.
For print, you will need to use a DPI calculator (or do the calculations yourself) to set the correct export size setting. Get the size you want in millimeters, convert it to pixels with the DPI you need, then set the export size to the resulting number of pixels.
Martam29
Dec 9, 2021 9:40 AM UTC
okay, I think it works just fine now!
Thank you so much Gleb, have a nice day! 😊
pratik1
Dec 11, 2021 7:21 PM UTC
hello everyone… i am new to figma. and i use to design my artwork. I have no interest in using as web/app design. Simple question - whenever i design something in figma and try to export it as PNG i want to select HIGHEST possible resolution but do not know how to set it before exporting. So when i exported it gave me a bad res png image around 300/500 px which is useless for me. Please advise.
thanks in advance
Power Member
Dec 11, 2021 11:23 PM UTC
Bretton_MacLean1
Jan 6, 2022 9:42 PM UTC
Still seeing this issue. I’d share a link here…but I can’t post links
Bretton_MacLean1
(vs a screenshot with the image at 100%)
