Will_Nandi
May 5, 2021
Export losing quality even using PNG and 2X higher
  • May 5, 2021
  • 93 replies
  • 91899 views
I am trying to use Figma as my main software to produce my designs.
But my frames are being exported with a bad resolution from Figma.
Exporting as PNG and even using 2X is not getting the full resolution as I see on Figma.
Anyone with the same issue?
Power Member
May 15, 2021
Can you show an example of the bad export quality and the original Figma file link?
Patrick6
September 21, 2021
I have the same problem. Where could I find solutions to this?
Hey @Patrick6,
Can you show an example of the bad export quality and your original Figma file link?
Patrick6
September 24, 2021
The first picture is a screenshot taken at 100% in Figma. The second picture is the same frame but exported normally.
Even without this comparison I have the impression that the normal export is not crisp.
Power Member
September 27, 2021
A post was split to a new topic: Export size limited to 4096px
Power Member
September 27, 2021
Can you share the Figma file link?
Patrick6
October 6, 2021
Is there a way to share it privately?
Power Member
October 7, 2021
Everything seems normal to me when exporting your file. At 1x I see some pixelation when viewing the exported image compared to Figma, but that’s because I use a Retina (high-res) display. Do you too? Or maybe you just use a custom DPI in display settings? You can enable pixel preview in Figma to see how the images would look like when exported:
Bretton_MacLean
October 20, 2021
Yeah I’m having this same issue. All my png exports are super low res. It is with great shame that I’m installing Photoshop on this machine to finish my work…
Tayler
October 26, 2021
I am having the same issue… created the exact same file in photoshop and it is a lot better. If anyone finds a way to fix it that would be amazing! I really want to be able to use Figma over photoshop
