Will_Nandi
May 5, 2021 10:48 PM UTC
Export losing quality even using PNG and 2X higher
I am trying to use Figma as my main software to produce my designs.
But my frames are being exported with a bad resolution from Figma.
Exporting as PNG and even using 2X is not getting the full resolution as I see on Figma.
Anyone with the same issue?
Daisy_Hsiao
Mar 14, 2022 4:24 PM UTC
Anyone found a solution for it? I’ve the same issue too, everything exported to be readable but not crisp at all, doesn’t look good.
May 2, 2022 5:10 PM UTC
I’m having the same issue. Has this been addressed yet?
Michael_Ragland
May 9, 2022 7:24 PM UTC
Same issue here. Exporting to png leads to bad pixelation. This thread appears to have been started almost a year ago. Has anyone at Figma addressed or solved this yet (apart from asking for examples)?
Power Member
May 10, 2022 6:56 AM UTC
Bretton, the second image is significantly larger than the first one. That’s why it probably looks blurry (or whatever the issue is).
@Michael_Ragland @anon6613461 examples? So many people say this is an issue but nobody sends any examples. It seems like Figma just did a bad job at teaching people how to export things in a way they want.
Andrea25
May 19, 2022 5:40 PM UTC
I am having the same problem, exporting png and jpg. Files created in Figma export are very pixelated, 2X. I am uploading to my portfolio and these are not up to par. Any suggestions?
Clement_Breton
Jun 3, 2022 6:34 AM UTC
Will you stop denying seriously ? Already 20 people reporting the same issue, + me now.
Power Member
Jun 3, 2022 6:43 AM UTC
So far the only examples people sent are solved by using correct export settings or viewing the file correctly (yes, even such a simple task as viewing the file is a problem for people). Please show examples. Without them, it’s impossible for me to say if you are doing something wrong or if Figma has a bug (in this case your example would need to be sent to the Figma team so they can fix it, otherwise — no example, no way to reproduce the issue, no fix).
peterstnsz
Jun 5, 2022 7:43 PM UTC
Anecdotal experience (this was quite a while ago): I had this issue on slow internet connection, and shortly after I’ve opened a Figma, document and exported an image - got a pixelated/low quality image.
Then I’ve refreshed the doc, waited for a while (extra minute or 2) and exported the image with a desired quality. I think it could be to do with Figma not loading fully the full (max) res image embedded in the document, hence the low resolution issue?
Justin_Jolliff
Jun 15, 2022 10:43 PM UTC
June 2022 and having this issue. @Gleb here’s a link to my game’s design with my imported files in figma + the files exported & brought back in for comparison.
Any thoughts? SOS
Figma – 12 Jun 22
Dan_Madden
Jun 29, 2022 5:41 PM UTC
same issue. I’m trying to export a favicon from a 16px artboard to three sizes:
• 16px
• 32px
• 96px
The results are very blurry, even though the object is a vector. Please advise? (the forum won’t let me post more than one image at a time, so here’s the 32px favicon)
favicon-realms-32x32
