Prototype is distorted/glitched in presentation mode
Show first post
Ricardo_Rios
I have created new files and used templates but that zoom still appears no matter what I do.
I have also tried on other computers, I don’t know if I changed any settings in my account or if it is a figma error.
I need help. What can I do?
  • 4710 replies
  • September 27, 2021
MUHAMMAD_ADIB_FARHAN_BIN_AHMAD
it work. Thank you so much for helping.
Samuel3
  • October 2, 2021
I’m using the desktop app
Please, I didn’t understand the first step you mentioned “Go to the properties of the Figma shortcut (right-click on the icon → “Properties” → “Shortcut” tab)”
  • 4710 replies
  • October 2, 2021
Right click the Figma icon like this:
Bern_O_S
  • October 11, 2021
When run the prototype presentation, the frame android image, does not fit with the telephone frame on the presentation, it is crazy because the links for the buttons are actually on the right place, but the image is just not well displayed on the back ground. how can I fix this?
Now I know is not only my problem because I saw someone post similar issue with the image problem post onseptember 4th. but they close the case after 30 day with NO answers.
Al_Mahdi
  • 5 replies
  • October 14, 2021
Actually disabling hardware acceleration will slow down Figma.
Al_Mahdi
  • 5 replies
  • October 14, 2021
Disabling hardware acceleration might slow down Figma.
Yakubu_Ibrahim_Muhammad
Encoutered this same problem but it can be solved by using Figma on a Firefox browser. The only problem is that your client may not be using Firefox.
Eduardo_Bertozi
Thanks man!
Camila_Leguiza
No puedo ver el prototipo, los wireframe salen todos defasados en figma de escritorio, en figma web y en figma mirroror
Ran_Gil
  • October 26, 2021
same probelm. i can only play the presentation mode in Firefox and it sucks!
why isn’t there a solution for that?
  • 4710 replies
  • October 27, 2021
There is, read the first post that is marked as a solution. 😅
jose_gonzalez1
como soluciono este problema
jose_gonzalez1
y en la aplicacion como quito eso?
  • 4710 replies
  • October 29, 2021
There are instructions in the first post.
Habeebu_Rahman
well if you are using Figma software in windows, u can create a figma.bat file with the following content which will solve the issue.
START C:\Users%USERNAME%\AppData\Local\Figma\Figma.exe --use-angle=d3d11
this file you can keep on desktop as an icon for Figma, whenever you click this - it will open Figma with a proper flag which solves the display issue.
Roberto
  • 9 replies
  • November 11, 2021
This solves only part of the problem. This doesn’t solve problem if distortion appers on the customers computer. In user test situation you can’t demand that customer start fixing this kind of stuff. This bug ruins user tests. Hope this gets fixed in Figma.
eddev13
  • November 23, 2021
F
Faz bastante tempo que a exibição do protótipo não está funcionando corretamente, eu já desinstalei o figma e deletei a pasta DesktoProfile mas mesmo assim não resolveu. O problema acontece tanto usando pelo navegador, quanto pelo app desktop. Alguém pode me ajudar como resolver?
  • 4710 replies
  • November 25, 2021
A post was merged into an existing topic: White vertical lines appearing in prototype/present
VICTOR_CHUKWUDI_ANIGWE
If the solution for windows desktop doesn’t work do this:
Wrap the file target extension in double quotes after the file path and the result will look like this
C:\Users%USERNAME%\AppData\Local\Figma\Figma.exe “- -use-angle=d3d11”
James_Medd
Agreed. Just experienced this in a remote user testing session and it was very disruptive.
wishwa
  • December 11, 2021
Hello i am new to figma.
I see there is a weird magnifier box when i open prenstation view.
How to remove this
Please Help
Tatiana_Bogomolova
Hi! I have a problem in presentation mode. How to solve it?
Sarah_Thomas
Yeah agreed, this isn’t a solution for people that are using prototypes to user test, especially unmoderated. 2/3 of my participants experienced this same issue yesterday. Please solve.
