macOS Desktop app not installing
Alex_Comsa
Figma desktop app - macOS
So, first of all for me the check for updates feature never worked. I click on it and nothing would happen. The only exception to this was when I actually checked for updates after a fresh install for the app. I usually just downloaded the latest version and then installed it manually.
Now, for a while the new versions available won’t install anymore and the app gets broken.
I tried everything: overwriting, fresh install. Same issue.
Here’s what happens:
  1. I copy the app into the Applications folder.
  2. I run the app.
  3. I get this progress window:
  4. After that’s done, the app is broken:
  5. When I open the broken app I get this:
I tried this a couple or times in the past month or so… same result.
Anybody got a fix for this? I’m currently stuck at version 97.7 which is the last one that works on my mac.
Thanks!
Best answer by poiru
These builds should work:
In order to fix the installer, it would be useful to know some more info:
  • Are you installing to /Applications?
  • Does your user have write access to /Applications?
  • Does auto-update work for other apps you have in /Applications?
tank666
  • 4873 replies
  • July 1, 2021
It will be helpful if you specify the version of the operating system.
You can also contact support: Submit a request – Figma
Alex_Comsa
  • July 8, 2021
OS version: macOS Catalina 10.15.7
poiru
  • Figmate
  • 21 replies
  • July 8, 2021
Studio1
  • July 9, 2021
I have the same problem but on Big Sur 11.2.1
Alex_Comsa
  • July 9, 2021
Thank you! The Intel build worked. I now have the (latest?) version: 99.0
Now I am wondering why the installer downloaded from over here does not work?
There is also a difference in size from the one you linked (88 MB vs 1.2MB)
How should I run the update in the future?
To answer all three of your questions: yes to all of them.
I use a regular account to work daily in Figma, but also use an admin account to install/move apps into the Applications folder.
Thanks!
Tim
  • 4 replies
  • July 15, 2021
I, and others had this issue as well. We reverted by installing an older Installer which is a lot “bigger”. The installer which downloads after the move to the applications Folder (installer around 1.4 MB size) always fails for us.
We are running 10.15.7 Catalina. We do not have permanent admin rights, but we can get admin credentials for a limited time frame and move the app into the applications Folder.
kpierce
  • July 20, 2021
I am also having the same issue, but @poiru 's download suggestion of
“Apple Silicon computers: desktop.figma.com/mac-arm/Figma.zip” download still produces an error message for me.
  • I am on macOS Big Sur 11.4
  • I am installing it to /Applications
  • I use an admin account to install and move apps to /Applications
Screen Shot 2021-07-19 at 5.55.57 PM
Is there another workaround for this, besides always using the browser version?
Betty_Wu
  • July 22, 2021
This issue happened here too.
Device: Mac Pro w/ MacOS Big SUr ver.11.2
Figma asked me to upgrade by downloading the latest ver. on official website,
or I couldn’t continue using it.
Then I :
  • download the installer
  • drag it into “Application”
  • became plainly white and failed to launch after installing
(it happened the same when I removed Figma before updating)
I will be really appreciated if there is any way to get it installed.
Thank you.
The intel build worked for me as well but I had the same issue before.
Betty_Wu
  • July 22, 2021
Thanks for your sharing. It works!
iulian
  • July 22, 2021
I have the same problem on macOS… the problem is that I lost also the old version and I don’t know how to put it back.
Dose anyone know how to fix it? @figma… please help
Mary_Pascher
The Intel Version helped thx! Had the same Issue as Alex
Sean_McIntosh
I had the same issue and the Intel version worked for me, Thanks @poiru 👍🏿. Maybe the “Figma for desktop and mobile” page needs some attention, the file I downloaded from there lead to the same issues experienced above.
Vine
  • July 22, 2021
Thanks @poiru, this should be updated on the Figma website, I just download the Mac version now and didn’t work for Intel Mac, luckily I found this thread
scott.robinson
Same issue with me Big Sur 11.4
Tessie_Szetho
I have the same issue. The Intel version worked for me. Using MacBook Pro - MacOS Big Sur 11.5.
Dan_Nye
  • July 23, 2021
I have the same issue on macOs Catalina v10.15.7 - the small (< 2MB) version always failed after downloading the update (it left a zero-byte Figma.app in my Applications folder)… buit the big linked Intel version just worked.
Why not just list the big Intel version at the download page, given it has to be downloaded anyway?
Javier7
  • July 23, 2021
thanks! I was struggling yesterday with this issue!
Justin_Low
The intel version worked fine! Figma you should update the file in the download page.
Julie7
  • July 30, 2021
Hi, I currently have the same problem on Big Sur 11.4.
I don’t have access at all to old versions since the computer I’m using is new.
The Intel build worked for me as well, so thanks @poiru !
Does anyone know what’s wrong with the installer on Figma website ?
Cesar_Moncayo
Problem solved to me. Thanks a lot.
I was just literally about to crash my iMac, lol.
Joan_Cazorla
Buenos dĂ­as un gusto saludarlos, justamente me esta presentando el mismo error. Le enviĂł la Version de Mac que uso. Muchas gracias.
preview-chat-Captura de pantalla 2021-08-09 a la(s) 9.05.51 a. m.
Pamela1
  • September 3, 2021
Hi guys! I have BigSur 11.5.2 and no Figma installation works. Please help!
Pamela1
  • September 6, 2021
And which one is the Intel build? Where can I find this? BR Pam
Guillaume_Caillet
Same for me !
