Is there a way to open an URL via plugin command?
  • August 26, 2021
  • 7 replies
  • 2410 views
Andrey_Shakhmin
I’m looking for a way to open an URL in a new tab to show some docs related to a certain command. Is there a way to perform such action via plugin’s backend script without spawning a hidden UI with iframe and all?
Best answer by Gleb
You can submit requests right on the forum in the #plugin-api:feedback category.
However, if you need the UI to just perform this action, it should be pretty easy, not much messing around:
const url = 'http://example.com'
const openLinkUIString = `<script>window.open('${url}','_blank');</script>`
figma.showUI(openLinkUIString, { visible: false })
setTimeout(figma.closePlugin, 1000)
  • August 26, 2021
No, it can only be done with a UI.
Andrey_Shakhmin
Hey @Gleb !
I’m new to this figma plugins thing, I bet you know the place where to submit feature requests related to plugins and the dev program. It’s such a pity there is no way to perform such a useful action without messing with the UI part of the thing. 🙃
  • August 26, 2021
Andrey_Shakhmin
Wow! Works like a charm! 👏 👏 👏
I thought it requires a lot more labor in order to do it. Thank you very much for the code snippet! 🙏
Govind_Chandran
Hey @Gleb
I was trying to open a url in the figma plugin itself using showUI and iframe but it shows 403 error. The link is opening in my browser window properly
figma.showUI( <iframe width="100%" height="100%" src="https://api.x.xxx.com/v1/oauth/google"></iframe>,
{ width: 750, height: 500, title:“Login to DevBud”}
Its for a google authentication process. That link is not the exact url but looks like it.
It feels like either CORS error or whitelisted domain error. Can you tell what it is and a workaround for it
  • February 28, 2023
Search for oauth in the API docs or forum, this isn’t as simple as that.
Govind_Chandran
What could be the issue, I have been going through the doc… no luck
