Hello,
I have the situation where I’m trying to use a toggle with variations together with variable hiding/showing layers.
I’m really not sure if I’m doing something wrong or if I discovered a bug, so I was hoping if someone could help me.
The idea is to have the dropdown item hidden when the second option “zi” in the toggle is selected.
I managed to get it working with variables, but for some reason it only works on double click?
Am I missing something?
Thank you!
One other I think I should mention is that the blue toggle is a component in an external library, with 3 variant types linked to each other “on click”.
Try reordering the actions so that the variable is set before the transition. Might be the same problem as posted here:
Hi, I was just following this Figma variables tutorial by DesignCourse about toggling colors on the same screen using Figma’s brand new Color Variables.
The idea is to change color of background using toggle button component variant and color variables combined. I just followed same steps but the results aren’t as expected while the tutor gets the results with same steps. I linked everything as instructed, but couldn’t sort it out for last three hours .
The file I’m working on is he…
Thank you, this works, although not when I also have an external library, the component needs to be inside the file. Just wanted to point this out for anyone else searching.
system
Closed
August 6, 2023, 2:34pm
5
