Figma Color variable not working as expected
Hi, I was just following this Figma variables tutorial by DesignCourse about toggling colors on the same screen using Figma’s brand new Color Variables.
The idea is to change color of background using toggle button component variant and color variables combined. I just followed same steps but the results aren’t as expected while the tutor gets the results with same steps. I linked everything as instructed, but couldn’t sort it out for last three hours 😦 .
The file I’m working on is here
Am I doing something wrong? or the beta Color Variables are not working as expected maybe sometimes? Please have your say if you sort out what I’m doing wrong in this.
Thanks in advance
Best answer by Hana_Vo
I hope this’s helpful. Mine runs smoothly.
Hana_Vo
The way I fixed it is I moved the “Set variable” section on top of the “Change to” section, and it worked.
Avokadomos
Thanks for this enlightenment. I’ve been struggling with this seemingly inconsistent behavior too. It does seem that the execution stops when the instance is changed. I will report this as a bug as it shouldn’t be correct behavior.
Avokadomos
Still seems very inconsistent for me. I’ve tried to recreate the issue now, but can’t. Can’t figure out what makes this one different:
Figma – 7 Jul 23
Hana_Vo
Woah! It works. Thank you so much! @Hana_Vo
