Variant instances problem - Please help!
  • August 19, 2022
  • 6 replies
  • 1095 views
Madan_Timilsina
  1. I created frame and added some text inside that frame
  2. Then i duplicated that frame and changed that text which is inside that frame
  3. Then i made both as component and combined as variants : “Default” and “variant1”
Now if i use instance of that component i will get property : Default and variant1
The problem is that when i change text of variant1, the text in default is also gets changes, but i want different text in default and variant1
Avokadomos
  • 377 replies
  • August 19, 2022
I’m following your steps but are not achieving the same result. How are you combining the components into variants?
  • 4873 replies
  • August 19, 2022
Apply different component text properties to the text layers of your variants. You can see an example here:
Madan_Timilsina
Madan_Timilsina
Here is my file please once can you tell whats problem in it:
https://www.figma.com/file/ZyuutY6Q0xlWAYbcT4RX1R/prob?node-id=0%3A1
  • 4873 replies
  • August 19, 2022
You have not added the component text properties to the text layers of your variants. I edited your file and now it works as expected.
Avokadomos
  • 377 replies
  • August 19, 2022
@tank666 beat me to it.
It works like this because the two text fields have the same signature, meaning the same name and same position in the layer hierarchy. Components will link layers that fulfill these requirements.
As for the second problem, the transition doesn’t work because the second variant does not have any interaction applied to it. If you want it to revert back to the default state, you can use mouse enter on default and mouse exit on varient1.
