@tank666 - just want to say thank you very much for this much appreciated. It appears I have to be extra careful when it comes to setting up the nested components.
I was stuck in a prior workflow before having to create two (2) separate components (light and dark) and then merge them via “Combine as variants” feature. So that ~ it seems, Is the “wrong” way of approaching this…
Once again thank you for your help once again,
Andy.
We are exploring the use of a spreadsheet to organize our Variant Properties, which also closely mirrors are Style structure, which also closely mirror our Event structure for analytics.
A colleague recently shared this checklist from Notion:
That did indeed fix the text problems! Thank you so much @tank666
Another issue I’m having is how these things are displayed when their size isn’t identical, even if auto-layout is turned off.
Here’s how it works in Adobe XD for an info icon with a hover tooltip:
Hover:
So as you can see it behaves like it would on an actual production web product.
Here’s the exact same thing in Figma:
Hover:
Auto-layout layer order screws up any drop-down or hover designing you’re doing by forcing the layer order so that top items are “below” items below them.
The item doesn’t retain it’s original position, instead the entire thing shifts.
That’s not how things work in real life products. This is just Figma being weird and restrictive on both accounts.
The only way to get around 1. is to disable Auto-layout, which is really damn stupid. 2. has no fixes afaik
So that the object doesn’t shift, it must be the same size, that is, the size of the variant with the showing tooltip must be equal to the variant with the hidden tooltip.
@tank666@jonoyoung - You guys seem to have figured this bad boy out. Well done! Now I’m running into the same problems, but in a different setup.
I’ve been trying to create an atomic based design system where we only have to make a couple of tweaks in one spot to change the entire system. I’ve been at it for quite some time now, but can’t seem to figure it out.
I took the following steps:
I’ve setup the _Button (size+style) component with responsive variants so that I only have to adjust the font-size, spacing, icon size & border-radius in one spot.
Then using an instance of the above component I created the component _Button states. This components holds all the different interaction states with prototype links.
And then finally I setup a component with all the different variants with icons left, right none, desktop, mobile, primary, etc. in the visible component Buttons.
Ran an experiment, but just like you guys text and colour overrides are all over the place…
The reason I’m setting it up like this because if you look at my file. The page “Lots of linking to be done” has two downsides:
When we duplicate a button to create another style; we then have to re-link all the interactions to the newly created buttons.
When we want to change a style we then have to - meticulously - change it over all 3 responsive sizes.
Hopefully one of you two could help me out. Thanks in advance!
Hi @YSluimer, it’s very difficult to guess where and what went wrong, whether it is related to the settings of the components/variants or even some kind of Figma bug. If you can share a video and a link to a example file, that will help us find the reason.
You can also take a look at my Figma Community file, which also uses a “.base” component for buttons.
Thanks for the link! I’ve experimented with your file and here’s what I can guess. The overrides were breaking because Figma doesn’t know how to define the state.
In your example, it read like this: “Any button with/without icon should be large and in the Default/Hover/etc state, and any size, and with some style”.
And it should be something like this: “Any button with/without icon and any size should be in Default/Hover/etc state with some style”.
I hope you understand what I mean.
You can see an example in the screenshot and the link to the file:
I think I had the same problem, but I managed to find a solution. I had a button group component consisting of 11 variants in which each of the 10 buttons were active (and one with no active buttons). The button I used was a component itself. My problem was, that when I renamed the button labels on my button group instance, sometimes (but not always?!) the labels would change to the labels in my button group component instead of the ones in the instance, when I clicked around in the prototype window - even though it seemed to work, when I cycled through the different variants in the editor. Very weird and quite buggy since I would at least expect to see the same behaviour each time, but sometimes it worked to just restart the prototype, and sometimes it seemed to me, that it would work if I clicked through the different instances slowly before clicking around like crazy, almost like Figma needed time to load all my different instance variants or something like that.
I found out, that I had accidentally changed the labels on the buttons in the button group component instead of just keeping the labels in the original button component. When I reset the text on the buttons in the button group component, everything worked. Hooray! But I still think something is buggy, since it would sometimes work with my original setup and sometimes not - it does not make sense to me, that it does not behave consistently.
After so many times I thought I’ve settled this issue last year once and for all in by utilsing proper .base / structure layering trees.
I still cannot fathom nor understood why Figma still at times simply refuse to keep text overrides. I decided to overhaul my form inputs.
Even if I made a direct instance of an instance. You would think this would keep text overrides. But no. I kept everything down to microcosmic rule and atomic principle advocated. But still it doesn’t retain text overrides.
Once again, a serious question of inconsistency. No matter how much I followed .base / structure / nested instances one after another and keeping all text layers, text name, layer name etc all the same ~ It still does not retain text overrides even if I make an instance as a new component and use that elsewhere.
The problem and solution is always the same, however it is usually a huge ask to have someone in this forum QA another person’s work due to how overly complex variant set layers get.
100% of the time, the solution has been to make sure that every layer name in every instance / variant is the same. If a variant has a different layer structure, or if a variant has a layer that is renamed, the text overrides will break.
The base component must have all of the layers, for every state and every variation. Simple hide the unnecessary layers at first, then turn them on as needed for each variant.
Check every single layer, expand every layer, in every instance, and make sure the layer structure and names are identical. This is a requirement.
BlockquoteCheck every single layer, expand every layer, in every instance, and make sure the layer structure and names are identical. This is a requirement.> Blockquote
I hereby request an open assesment on my Drop Down section of my design system below ~ for anyone, to assess whether or not how I laid out my Drop Down components - from their .base/structures to usage case scenario is in any way abnormal or simply not “industry-standard” or not atomic-principle standard. I have checked every layer name to ensure they’re the same. I have inspected all titles, headers and text bearing exactly the same name as they were according to my .base / structure.
First is the base structure and setup for the dropdown.
Second is the testing ground and where I set initial text overrides.
Third is the form builder area.
TLDR; When the drop down overall setup component is used in the .base form builder - It still somehow does not retain text changes in its variant open/closed states. Even if it appears to work ok during the Testing Ground / artboard #2.
Amongst other problems - Figma still struggles, lags and crash even in the most simplest of form prototyping (no smart animates, linear on/off, etc).
