Shadow effects doesn't show in component, but shadow is visible when I move component into another project
  • October 21, 2022
  • 668 views
Michal16
Hi, I got a strange problem with applying shadow effect from design system library. In right panel shows as applyed but It’s invisible in component. Shadow is visible when I move component, or instance to another Figma project. Why it’s invisible only in that specific page?
Gabriel_Rosado
I have a similar problem with the drop shadow. I created a drop-shadow effect that uses the Spread attribute (x=0, y=0, blur=0, spread=3). If I apply it on a Rectangle element it will display but if I apply it on a component or instance it will not show, even though the style panel says it’s been applied
Nino_Strixner
Same here!
