See where component is used / find component Instances across files
Dennis_N
As editor and maybe also as viewer I want to be able to see where specific components are used. So I’m basically talking about way to find instances of a component across files.
There’s a plugin called “Instance Finder” but unfortunately it’s just working within one file not across.
For huge design systems with multiple files and different designers working on it this is far from ideal.
This idea is not new but since the other topics are closed I guess I need to open a new thread.
See:
https://forum.figma.com/t/finding-component-instances/6477
We few can’t be the only ones who are missing this feature. Are we?
Kamaljeet
    I want to be able to find instances of components within my Figma file.
    For a huge design system with multiple designers working on it, I often need to find molecules and all the places they’ve been used (organisms/templates), etc. For a big design system, this becomes very difficult and adds a lot of manual time to sift through the hundreds of components and organisms.
    There’s already a plugin called “Instance Finder” but it doesn’t work on large design system files.
Laetitia1
It will be an interesting feature
Erin-UX
It would be nice to have this as a native Figma feature. The plugin has its limitations.
Nicole_Saidy
It seems like our wish just came true because Figma literally just added support for a global search where you can search for component instances, on view-only files too! https://twitter.com/figma/status/1578046779983011842?s=46&t=wRFgjeJOGqitvkQU7Krsjw
You’d still have to search page by page but for me this is a HUGE improvement. I am now able to search for an instance on a page and find the instances and move through them, rather than literally looking for instances frame by frame!
Tingting_Cheng
I’m still having trouble with this feature. I have ‘Used in this file’ instances that have been removed from the original file. But when using the search feature, the component does not show up. So I’m still not able to find ghost components. I believe it’s also not working for hidden stuff…
Nicole_Saidy
are you sure you’re searching in the right page? I had this issue too then I realised the search feature works only on the page level and does not search in the entire file… you’d need to search page by page.
  • 4873 replies
  • October 7, 2022
You are wrong. The search function can work on the entire file. To do this, just click the “See results on other pages” item or select “All pages” instead of “This page” in the drop-down menu.
search-function
Nicole_Saidy
brilliant, didnt see that. Thank you!!
Tingting_Cheng
Even with this feature I can’t seem to find ghost instances 😦
  • October 7, 2022
It would be interesting to take a look. Could you share an example file?
Dennis_N
  • October 7, 2022
Yeah that search is nice but I really would like to search across files.
Regarding Tingtings issues: For me hidden components indeed are not findable.
Ghost components on the other hand I am able to find (within a file).
Tingting_Cheng
In the attached images you see I have a dropdown field used in this file, when I go to the master component, I’ll go to the file where it used to be, but it’s saying the component has been removed. But when I try to search for it in the file, there are no results 😦 annoying as hell
Tingting_Cheng
Hm perhaps it’s a hidden ghost component then? 🙄
Tingting_Cheng
Little update; I managed to find my ghost instance by manually removing stuff per page and putting it back lol. That’s what I do when I’m desperately trying to get rid of ghost components in the assets panel. Anyway, I think the search feature is still buggy, because as it turned out indeed, the instance was hidden. But even after unhiding it, it still doesn’t show search results…
Blackwood
Just adding my weight to this. It’s absolutely essential to maintain a complex, organisation-wide design system.
Really hoping Figma is working on it.
Blackwood
Not across projects, though, which is essential to find uses of design system components.
Blackwood
This is literally the one feature missing to enable effective use of Figma to maintain organisation-wide, cross-product design systems.
It’s essential to be able to find where your components are instances are in any file and to preview what impact updates will have.
Tingting_Cheng
Man, this would be a TOTAL game changer. All those plugins are either too slow or simply do not work on large files or across multiple files.
Nicole_Saidy
@tank666 I actually cannot search through pages in a view-only file, only one page at a time. Not sure why. And this is my usual use case (searching through other people’s files that i dont have edit access to, to find component usages)
  • October 19, 2022
I don’t know if this is a bug or a missing feature in view-only mode.
If the former, please report the bug to support via this form: Submit a bug report. If the latter, then create a feature request on this forum under the #share category.
Mark_Carroll
+1 - We need this
Carey_Smith
  • November 4, 2022
This was easy to do in Sketch 3 years ago. Robust component handling is something I really miss from Sketch. Things like notifications when a component you’re deleting still has instances and where they are, easy copy/pasting master components between files without detaching instances. I’ve used Gleb’s Master plug-in, which is helpful, but Figma should really support these things in product by now.
Canepa_Alberto_ELS-AMS
Yes, we need this feature as well. Maybe an idea is to add it also as part of the branching review flow upon merge or publish
I have been waiting for this feature to make it in.
Maria_Lyons
Silly workaround, but it helped me! I just edit the background of the component to be an obnoxious color that’s not used in my file. Then I go through the pages zoomed out looking for that color. Another option, which would let you find it in the layers, is to add text to the component that says something unique like “Find me – I wish Figma could do this!” and then do a find on that text. Yes-- I’d rather right-click on the component and choose “Find instances”… but until then, this trick will work for me.
