Multiple boolean checks to enable a button
Isaac_Sonnenburg
I’m working on a form prototype. I would like to have the progress button in a “disabled” state until the tester clicks two separate check boxes, at which time the progress button is enabled and the tester can progress.
Currently, I have 2 different check boxes made with variants. When the tester clicks on one of the box variants, the box becomes filled, and it’s specific variable goes from false to true.
My problem is that I can only assign a single variable to the progress button variant, rather than multiple. I’ve tried assigning multiple variables to the varient, but it “enables” the progress button if either of the check boxes are clicked rather than both.
Normally I’d have the progress button listen for both the variables so it would look something like:
if box1 == true and box2 == true
then
buttonState == true
but I can only script something like that through an action, like on click, rather then it be passive.
Am I thinking about this all wrong within the confines of Figma, or is this something that just can’t happen yet?
Thank you!
Best answer by Haroll
Hi @Isaac_Sonnenburg
then
buttonState == true
Rather than binding this logic on the button you can bind it to the checkboxs since they have an “on click” event. Obviously it’s not perfect, you will need to rewrite this logic in every interaction capable of changing the final outcome, but it’s working
Haroll
  • August 9, 2023
then
buttonState == true
  • August 17, 2023
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
