Is there a way to make zoom in on hover effect for images?
  • November 16, 2021
  • 5 replies
  • 24449 views
Pavel_Guzenko
I want to make for all images in my design Zoom in effect on hover (while hovering). So far the only way I can see is to make a Frame with Open overlay on top with Dissolve animation. As you can image it’s not in any way looks like Zoom in effect. I can also make for each image a separate artboard and use Smart animate, but then I will have to have like tens of artboards. Is there a simpler way?
Best answer by tank666
Hi @Pavel_Guzenko, it’s very easy to do it.
  1. Create two components: 1st — default state; 2nd — with an enlarged image.
  2. Combine them as variants.
  3. Create a “While hovering” interaction using an “On change” action between variants.
  4. Add an instance of this component to your frame and run the prototype.
If you need a file, let me know.
  • 4873 replies
  • November 16, 2021
Pavel_Guzenko
Yes. I actually figured out myself already. But thanks anyway! 🙂
Adi_Chomski
hey! i would appreciate a more detailed explanation if possible. thank you!
  • 4873 replies
  • December 2, 2021
I made an example for you. Duplicate this file to see how it works.
Design file:
Figma – 2 Dec 21
  • January 1, 2022
