Image Override breaks smart animation
Joshua_Fry
When overriding an image within this interactive component, the hover state animation breaks, so that the animation transitions through a blank rectangle instead of remaining as the same image as it does with the original version. This should be clearer from the example show in this file.
Chris_Austin
I am having the same issue as you can see here in this loom.
And here is the interactive component that makes up the menu :
Jc_Martel
  • 36 replies
  • March 31, 2021
Check out this other post. It might help you fix your issue:
Hoping it’ll help!
Renata.Alves
I’m having the same issue. Figma should understand the overridden images, I shouldn’t need to create another group of variants with the images that I may use in that component.
Yulia
  • 39 replies
  • April 7, 2021
+1
This is an unpleasant problem, I really look forward to her decision
