I’m having issues with interactive components, especially with images.
Here’s a component that is basically a frame with an image background.
On the left, the original comp, no change, hovering is fine.
On the right, I replaced the background image, Now when I hover, there is a delay between the default state and the hover state
Note: both images are compressed.
Check out this other post, you should be able to fix your issue:
there is no solution only a replica of the problem
Having same issues.
