I recently, or better, had since a year of trying to fix it, the issue that any font i downloaded did not work. (Exept for the sega logo font, which isnt on my pc.) draging in the file does nothing. Restarting, reinstalling everythinf including fonts and the desktop program / font-into-figma-shover in various ways, downloading diffrent fonts did not work, manualy installing fonts did not work, and yes, i did restart, shutdown and start, and updated figma in a year. So, since i now KNOW that the problem is not coming with a clean instalation of figma and is not caused by me. i recently also found out that a bot answers the questions after that by leading to a help article that explains you how to install fonts, not troubleshoot, just installing. the troubleshooting page for the issue that has been “solved” and the answer pointing this page out was “most helpful” (figma closed the thread by sending the user to an irrelevant page) was about Adobe fonts not showing up. i have the same issu
It would be great if the professional plan offered more than 4 variable modes. Right now I want to set up a mode for each component size-- XS - XL, 5 sizes all together-- which puts me over the 4 limit for pro, but well under the 40 limit for enterprise, which is a quantity I will never need. And there’s no use case for enterprise at all for a team our size. I think 10-12 modes for pro would be perfect to give small teams like mine room to grow before we reach the scale where an enterprise plan would be worth consideration.
I have prototypes with pop out modals, when I present these appear fine unless I go into “Full Screen Mode”. In which case the pop out modals disappear and the prototype skips any pop out modals when clicking through.
I’d love to suggest a small but potentially powerful feature:a local clipboard panel inside the canvas. Think of it as a lightweight, always-visible spot where I can quickly drag elements I create during a session and reuse them throughout the file — like a mini asset shelf, but temporary and personal. 🎯 Use case: While working on complex screens, I often create utility elements (buttons, arrows, highlights, etc.) that I need to reuse across multiple frames. Right now I either copy-paste from frame to frame or scroll back and forth.With a built-in clipboard panel, I could drop those elements in one place and simply drag them out when needed. That would seriously reduce navigation time and context switching — especially on large-scale design systems or messy exploratory files. Attaching a quick visual mockup of the idea for clarity.Would love to hear what you think!
Hi Figma team, I'm building a website using Figma Sites (https://www.marilialeal.com.br/), and I've encountered a major issue regarding SEO and search engine indexing. The site is automatically generating the following tag in the <head>: <meta name="robots" content="noindex"> This prevents Google Search Console from indexing the site, and there's currently no way to remove or override this tag through the Figma Sites settings. I’ve tried adding a new <meta name="robots" content="index, follow"> tag as high as possible in the Custom Code section, but it’s still ignored by search engines because the noindex tag appears first. This makes Figma Sites unsuitable for any project that requires SEO or public visibility on search engines. Could you please provide a way to: Remove or override the default noindex tag in the <head>; Ensure that published websites are indexable when desired; Clarify whether this is an intentional limitation or a bug? Thanks in advance. This is a critical blocker fo
Very low performance speed in Figma Make when the thread reaches large sizes (currently 230+ iterations). All actions in the chat area occur with a significant delay (typing, scrolling, etc.), making it impossible to work. However, the prototype itself works well within FM. Has anyone encountered this? What could be the cause? Could it be related to the power of the laptop?
Hi, I’m having an issue with the variables. I created a design system with all the relevant variables and then published. I made sure all variables are with the correct scope details and all are NOT hidden from publishing. After enabling that library in a new design file, i tried to use a color variable on a new shape and it simply doesn’t load the colors in the small thumbnail squares. They just stay forever with the default color variable icon. I tested this with new files and new libraries and variables but the issue keeps happening. It seems like it is stuck in a forever loading stage. Other colleagues of mine can use the library and see the variables in their square thumbnails, so im guessing its my issue. After this i made sure my figma was updated and even uninstalled it and installed again. I’ve also tested this with both app and web browser. Interestingly, when i do select a color from the variables on the right panel, the color appears! Has someone had this issue? I’m really
Hi Figma team, I’ve encountered an unexpected behavior when using Auto Layout with negative gaps. When a zero-width or height element is included in the frame, the negative gap is ignored, and spacing defaults to 0. Steps to Reproduce: Create an Auto Layout frame with a horizontal or vertical direction. Add multiple regular elements (e.g., rectangles) — negative gaps work as expected. Add a zero-width or zero height element into the same Auto Layout group. Suddenly, the negative gap no longer works — the spacing defaults to 0, breaking the layout. Would appreciate if this could be looked into. Thanks! Changing the gap reveals that only the Auto layout frames without the zero size element are able to have a negative gap value
Hi, I have lost my most recent and the most important file on Figma and I can’t find the file in any of my projects section or in the deleted section. It just disappeared completely. I am the sole owner and editer for that file. It wasn’t a file in a team and it wasn’t in the deleted section either. I didn’t delete the file. I think maybe a bug in the “drafts to move” update on Figma, which I clicked a few days/weeks ago. Today when I launched my figma, it briefly told me the file transfer is still in progress? but then there’s nothing. And I have checked my emails to see if there are any teams deleted and nothing there too. Can the backend see or have the names of all the design files I created, deleted or moved somewhere. Maybe that can help what happened to the file. Again, it was my most recent created and edited file. I really needed that file, it contains all my works from my last company that laid me off a few months ago. Please help.
Good afternoon)) Pop-up is configured in prototype. When you hover over the buttons at the bottom, the pop-up closes, although there is a Close button at the top right. How to remove the pop-up closure. Also, one of the frames with information inside the pop-up is hidden. How can I fix this?
Hello Figma Team,I accidentally purchased 2 additional Dev seat accounts and was charged accordingly. I would like to request a refund for this accidental charge. Could you please let me know if a refund would be possible in this case? Thank you very much for your support.
Find answers, learn more.
