SAFO Apresentações
Jul 4, 2025 2:41 PM UTC
Unable to Remove meta name="robots" content="noindex" from Figma Sites — Preventing Indexing by Google
Hi Figma team,
I'm building a website using Figma Sites (https://www.marilialeal.com.br/), and I've encountered a major issue regarding SEO and search engine indexing.
The site is automatically generating the following tag in the <head>:
<meta name="robots" content="noindex">
This prevents Google Search Console from indexing the site, and there's currently no way to remove or override this tag through the Figma Sites settings. I’ve tried adding a new <meta name="robots" content="index, follow"> tag as high as possible in the Custom Code section, but it’s still ignored by search engines because the noindex tag appears first.
This makes Figma Sites unsuitable for any project that requires SEO or public visibility on search engines.
Could you please provide a way to:
  1. Remove or override the default noindex tag in the <head>;
  2. Ensure that published websites are indexable when desired;
  3. Clarify whether this is an intentional limitation or a bug?
Thanks in advance. This is a critical blocker for using Figma Sites in production environments.
Best regards,
SAFO Team
Hoa DO
Jul 7, 2025 7:39 AM UTC
I am facing the same issues. Starting from June 3rd, all my pages went unable to be crawled by Google. It would be great if there is a way to bypass or fix this.
Jul 15, 2025 9:55 PM UTC
Hey All, thanks for reaching out!
To resolve this search engine indexing issue, you'll need to check your website settings. The noindex meta tag is likely being added because the "Exclude from search engine results" option is enabled for your Sites files.
Here's how to fix this:
1. Open your Sites file
2. Click the Settings icon in the left navigation bar
3. Select General
4. Look for the "Exclude the website from search engine results" option
5. Make sure this box is unchecked
You can manage this setting both site-wide and for individual pages. Once you've made this change, you'll need to republish your site for the changes to take effect. After republishing, the noindex meta tag should be removed, allowing search engines to index your site.
Here is our guide that includes these details for more information: Edit website settings
Hope this helps!
Lily Brooks
Jul 26, 2025 6:39 AM UTC
Your concern is valid having a default <meta name="robots" content="noindex"> severely limits SEO potential. Figma Sites must provide an option to control indexing behavior. Without this, it's unsuitable for production or any SEO-focused projects. This issue needs urgent attention from the Figma team.
Léo Cosmic Shelter
Aug 25, 2025 1:09 PM UTC
To resolve this search engine indexing issue, you'll need to check your website settings. The noindex meta tag is likely being added because the "Exclude from search engine results" option is enabled for your Sites files. Here's how to fix this:
3. Select General
Hope this helps!
I Unchecked that checkbox and published a couple of times since then and the  “<meta name="robots" content="noindex">” is still there. Will it be fixed soon?
The Creative Wright
Mar 12, 2026 10:41 AM UTC
I have:
  • Checked the setting was off
  • Turned it on, republished, then turned it off again and republished (twice)
  • Confirmed the site is live and accessible
  • Verified in Google Search Console that pages are being excluded due to the noindex tag
Despite this, Google Search Console still reports “Excluded by noindex tag”, which suggests the tag may still be present in the page header or being cached somewhere.
Could you please check whether:
  • The noindex tag is being correctly removed on publish
  • There could be a caching delay on Figma’s hosting
  • There is anywhere else this setting could be applied unintentionally
This is currently preventing my site from being indexed.
Thanks in advance for your help.
Mattiaaaaa
Mar 12, 2026 12:31 PM UTC
I’ve created a project in Figma Sites and connected to my domain with DNS. In the file settings, I’ve made sure to uncheck the “Exclude from search engine results” option.
However, after publishing, the noindex meta tag still appears in the site’s head when i try to do index in Google Search Console. There are no noindex tags in my code.
Can you please help me with my problem.
Site URL on my domain is https://geomarketingia.com/
itspauljnicoleson
Aug 5, 2026 6:12 PM UTC
Hi Figma team,
Best regards,
SAFO Team
This is definitely an important issue. If a `noindex` meta tag is being added automatically and users can't disable it, it essentially prevents the site from receiving organic traffic, regardless of how well the content is optimized.
For anyone planning to use Figma Sites for a production website, having control over basic SEO settings—such as `robots` directives, canonical tags, meta titles, descriptions, and sitemap generation—is essential. It would be great if the team could clarify whether this behavior is temporary, a bug, or an intentional limitation while the product is still evolving.
Hopefully this gets addressed soon, because the overall publishing experience is promising, but indexability is a fundamental requirement for public-facing websites.
Paul J Nicoleson
Kengo Sawa2
Nov 13, 2026 1:26 AM UTC
After changing the “Exclude the website from search engine results” setting, make sure to republish your site for the change to take effect.
I had the same issue, but after republishing, Google Search Console confirmed that my site was eligible for indexing.
This worked for me, so I recommend giving it a try.
