Hello to the community
I really need help to solve this strange behavior:
I lost the color information when hovering on a nested component
Here is a video
No problem, you can make fun of my English
Thank you in advance
Here is a video
I updated the demo for a better explanation
I’m experiencing the very same issue. It’s the first time i discovered a bug in Figma after using it for several years… Strangely it happened after Adobe purchased Figma. A coincidence?
@Figma_Support
Please help quickly on this…
Too much interactive component troubles are happening
I can’t rely on Figma if what my customer sees/experiments is not what is intended!
I also want to precise that everything was working the last 3 month, nothing have change in those component.
My file seems to be repaired without having modified anything
Thanks @figma to have stabilize it
@Fred_Tinsel really? I still have the issue. Maybe it’s a floating bug. Cause I had this issue ~2 months ago, after 2 weeks it seemed to be fixed. But now I have this issue again.
@Artem-Moskovskikh In the component, on the instance, try to reset all change.
And relaunch the proto
Hope it works for you too
@Fred_Tinsel unfortunately it doesn’t work… what are in my case:
I have:
The bug occurs in prototypes when hovering on icons — color are not as I made. I see the source color of icons.
