Having trouble with text box sizing
  • February 17, 2022
  • 4 replies
  • 14704 views
AJ13
I can NOT figure out how to get the text box to hug the actual text. It is either waaaay too small…or if I resize the box by hand, it’s in the wrong place (it grows downward from about half the height of the type.)
Anybody know what might be going on? I can’t find this particular issue anywhere in the forum or on the wider internets.
Best answer by Klesus
Like tank666 says you need to check your line-height, but if you resize the boundingbox then you need to set the sizing to auto width.
Or is it that you want to change the font size by dragging the boundingbox? AFAIK you can’t do that unless you flatten the text, but then you won’t be able to edit the text. A workaround could be to holding down Ctrl / Cmd and drag the font-size.
  • 4873 replies
  • February 17, 2022
Klesus
  • 237 replies
  • February 17, 2022
AJ13
  • February 17, 2022
Perfect, thank you both. I knew it had to be something simple since no one else was having the issue haha. Got it now!
  • March 19, 2022
