Hi, After the update, I can no longer copy individual CSS style properties. Now it’s only possible to use the copy button, but in that case it copies all the styles.
We host the web page in figma.site servers , but i want to host my own html files in my server ? how can i get these files..
I faced this problem on and not off but couldn’t really find any patterns. Sometimes, figma make is hallucinating with my prompts and giving weird screens (replacing existing screens) and giving wild outputs. After some time or the next day, the problem is getting fixed. For sure, the problem is not with the prompt, the problem starts with the way it is reasoning it. If this can be fixed, it will be really good because the flow is getting cut quite often.
I would like to be able to selected multiple child components which are all associated with the same parent component and edit their shared nested instance properties across all selected child components.
As a designer I would like to record my prototype screen or export it as a gif so I can use it in presentations and send quick examples in the team group. It would be great to have the same feature then Principle to record or export the prototype to gif. Does anyone have the same need? Is anyone using a plugin or workaround to help solve this?
Hi community! I create a product card component with 2 variants. And when you hover over it, it will switch to the variant below. Both variants have an arrow, and the arrows have the same name as well as the same place in the hierarchy. They are connected with smart animate. I assume that when you hover over it, the arrow will not have any animation. However, when hovered over, the arrow will disappear and reappear. This is a clip of what it looks like when you hover over it. https://www.youtube.com/watch?v=SRa1mFr_61A How can I make the arrow just stay there? Is this behavior normal? Product Card Component Arrows in their respective hierarchy. The smart animate set up
I’ve been using Figma Make for a while and almost crossed 650+ versions. Now, whenever I input a prompt, the prompt is working on the file, but version history is not showing. “Reasoning” is the status which is visible, nothing other than that. Now I can’t do a undo to my previous versions.
I can no longer drag and drop variables. Just yesterday, I was able to rearrange colors, strings, and numbers. I’ve tested this across multiple files and accounts, but it no longer works in any case.
It’s currently too easy for contributors to make small changes that go unnoticed by maintainers. Especially in large files, there’s no way to track exactly what changed. Enforcing that the main file cannot be edited unless you branch will allow maintainers to view exactly what has changed and require reviews of contributions.
Over the past week, I've been having a problem exporting images. Some parts of the text or frames are shifted by a few pixels, as if they were cut out. At first, I thought the problem was with the font, but it turns out that this problem occurs with any font. I tried all methods, but the only solution I found was to shift the text and frames by a couple of pixels. Has anyone encountered a similar issue and knows how to resolve it? The text and frames have integer values without fractional parts and are tied to the pixel grid. Changing the file type to JPEG or PNG does not help either.
I am using Figma Slides and when adding Live Integration - Stamps the frame or text gets cuts in design mode and in present mode the whole Stamp frame/box gets cut on top and bottom. Design Mode - text in Stamp does not display in its fullness Present Mode - Stamp gets cut on top and bottom
Figma has been distant from users lately, and while I understand that they’re expanding their scope, the contact support button has become completely unresponsive. Here’s what happened: I transferred ownership of a file in a project from User A to User B, since B would now be managing it. B then removed A from the sharing settings and restricted access to invited users only. However, A still had access to the file and, assuming it was no longer needed, moved it to the trash. B was shocked to find the file was no longer accessible. When A tried to recover it from their trash, it wasn’t there. B also couldn’t find it in their trash. Now the file is gone — not visible in either A’s or B’s trash, and inaccessible to both. The question is: where is the file now? And I am here is community is because As i mentioned The contact support button doesn’t work. BTW although this ask seems chilled, I am losing my mind on where the file is because i have a deadline to meet.
Hi All, please help. Figma’s on drag interaction is not working.
Hi everyone, I’ve been using Figma under an Educator plan, but I’m no longer eligible and I’d like to switch back to a regular plan. Additionally, I now want to transfer all my files and projects to another existing Figma account (not just downgrade the current one). Is there a recommended way to: Transfer ownership of all files and team projects to another Figma account I already own? Make sure I don’t lose access to any important files or lose shared permissions? Close or downgrade the Educator account cleanly afterward? Any help or step-by-step guidance would be much appreciated. Thanks in advance! Best, Axel
Find answers, learn more.
