Viswakanth S
Jul 22, 2025 5:21 AM UTC
Version History stopped appearing in Figma Make
I’ve been using Figma Make for a while and almost crossed 650+ versions. Now, whenever I input a prompt, the prompt is working on the file, but version history is not showing. “Reasoning” is the status which is visible, nothing other than that. Now I can’t do a undo to my previous versions.
Viswakanth S
Viswakanth SSolution
Jul 25, 2025 11:00 AM UTC
Thanks Junko. I created a copy and within two prompts, the issue got fixed. I happen
Jul 23, 2025 6:06 AM UTC
Hi ​@Viswakanth S,
I understand you're experiencing an issue in Figma Make where only 'Reasoning' appears after you input a prompt, preventing you from undoing to previous versions.
To cover the basics, could you please try a few things?
  • Click "Refresh preview" at the top left of the preview to see if it starts working again.
  • Try refreshing the page and then prompting the model again. You could also duplicate your Figma Make file and try prompting in the copy.
You can also refer to this article for more troubleshooting tips: Troubleshoot in Figma Make
If the problem persists after trying these steps, to allow our team to investigate this further, please fill out this quick form: https://figma.bot/submitreport.
In the form, please share the URL of the file where you're seeing this issue and grant edit access to support-share@figma.com. (Please rest assured that granting this access will not impact your billing.)
This access will help us reproduce and investigate the problem more effectively.
Viswakanth S
Viswakanth SAuthorSolution
Jul 25, 2025 1:02 PM UTC
Hey ​@Viswakanth S , I am working closely with Junko!
Thanks for letting us know, and glad to hear it’s working on your end now! I’ve gone ahead and marked as solved your topic. Thank you
Projectworks
Aug 21, 2025 5:28 AM UTC
I’ve encountered the same issue numerous times, not being able to rollback, and lost days of work. ​@Viswakanth S How did you fix it?
