I’m having issues with typing out text on the file canvas for the chrome desktop and browser app. Guessing it’s not a font issue since it’s inter. Not a bounding or frame issue since I’m typing it straight onto the file canvas. No issues when I type it into an art board, within another layer/frame or have a background behind it. It’s like the file canvas has “hidden” frames that the text hides behind (see image). If you zoom in and out you can find a level where it is visible like normal, but if I were to adjust the zoom just a little bit it turns invisible again. I can’t see the text written when I select the area either. I’ve tried restarting the desktop app without any success. Not sure if it’s an issue with the Asus model I’m using since it seems to work fine on my stationary chromebook at work.
So I have tried prototyping the keyboard, but i dont understand how can i do it? Some people say that figma is not a great tool to do that. What should I do?
How to copy and paste text from Word documents has changed. I’m having trouble pasting into text boxes in particular. When I copy and paste text from Word it appears as an image in Figma. I have to paste as an image using CMD+V then repaste with CMD+SHIFT+V for the text to paste into a box. Has the way you copy and paste changed in Figma recently? It seems this little difference is adding quite a lot of time to my workflow at the moment.
I think the "contact us" function is very poorly designed and has caused me a lot of trouble. After submitting my feedback, such as a request to modify invoice information, I only received a toast message saying "figma will contact you soon". However, I have been using figma for 3 years and I don't know how to contact you. Until today. I think you should provide us with a way to contact you, such as a link on the webpage. After confirming, the pop-up window should disappear. Otherwise, it will cause a huge and unnecessary workload for customer service. I hope you will seriously consider this。
When I copy any Figma frame using Cmd+Shift+C (copy as png), it gives a message “copied as png” but when I try to paste it in google slides, it doesn’t work. As if there’s nothing in the clipboard. Tried clearing the clipboard still doesn’t work.
Hi, I tried to update my simple Plugin, which I originally added back in 2022. Unfortunately, I got an error which is blocking the update. I also noticed that when I click on the “Permissions” tab the dialog box closes right away. So I don’t know if there is missing something.I also don’t use the E-Mail address anymore, which I added back in 2022. I have no access to it anymore. Instead, I would like to change to the one I use in my account. Any idea what is going wrong?Thanks, Danny
I cant click in this blank area to apply fills/strokes/effects etc, i used to be able to but now i have to click the plus. it takes a little longer to navigate there which is a bit annoying, is this a new thing or a bug?
Hi! Turning off “snap to pixel grid” in a Figma Design file no longer changes snapping behavior when dragging frames around. Whether this feature is turned on or off, a dragged frame still snaps to each pixel, no matter how zoomed-in. Note that some other objects (e.g., vector objects) still respect this setting. It’s just an issue with frames, components, and component instances. Note that If I group the frame, I then can drag the group to any sub-pixel location. I’ve restarted my machine, restarted Figma, checked for updates, reloaded tabs, tried it in other design files. Tried it in the client, in Chrome, and in Safari. Same problem. Can anyone else replicate this?
I'm encountering an issue with the Variables API endpoint when attempting to export local variables. The endpoint returns all remote variables from shared files, making it impossible to export only local variables. Current Behavior: The endpoint returns all remote variables from shared files Unable to filter or export only local variables Receiving a 400 error with "Request too large" message Error Response: { "status": 400, "error": true, "message": "Request too large. If applicable, filter by query params." } Technical Details: The error message suggests using query parameters for filtering However, the endpoint documentation doesn't list any available query parameters The endpoint lacks pagination capabilities This limitation makes the endpoint essentially unusable for files with many variables Expected Behavior: Ability to export only local variables Support for filtering variables (local vs. remote) Pagination support for large variable sets Impact: This issue significantly impact
I hope to add the function of path gradient, which is very useful for logo design.
Hello, I had several issues regarding transferring ownership. According to the free plan, only two people on the team have permission to edit. So had removed other team members so there are only two members in the 'team project;. I was still unable to transfer the ownership to the other or edit so I have upgraded to 'professional'. Neither of my member and I can edit or do anything about this file which must be editable since I have upgraded my plan. The admin who created this team project is no longer with us, so we cannot reach out to the admin. Please help me.
Hi!I've recently run into a strange issue when exporting frames from the Figma desktop app (Windows). Some slides/frames export with black bars on the edges (top, bottom, or sides) - but only in certain cases. Here's what's happening: Everything looks totally fine in the browser version - no black bars there. The issue only affects some frames, not all. In the editor, the frames look perfectly normal - the black bars only show up in exported images. I’ve tried: Reinstalling the desktop app Clearing the cache Making sure all layers are aligned to whole pixels Removing shadows and effects that might bleed outside the frame Exporting in PNG, JPG, and SVG — same result Has anyone else run into this? Would love any ideas or workarounds. I’d really appreciate any help 🙏 Hope I explained it clearly English isn’t my first language, so I hope it all makes sense! 😩
Everytime I leave Figma window to go to another window, I get this “New available font: Raleway” notifications. Why is this happening? How do i turn it off?
Find answers, learn more.
