Feature Request: Allow changes to text case independent from text styles
  • February 15, 2023
  • 1111 views
dennsi
  • 256 replies
Hello everyone!
Currently, if you use text style on a text and you change the text case, for example from default to uppercase, the change will detach the applied text style.
If you want to use text styles combined with different cases you’ll need to set up multiple styles which can lead to a lot of maintaining work.
To be able to apply other case settings and keeping text styles intact and independent would be a great improvement. And in my opinion text decoration (underline, strikethrough etc.) should also be unproblematically applicable if text styles are used. Just like text alignment changes.
What do you think about this?
See more details in this topic:
  • May 16, 2023
